How many? - Ford Truck Enthusiasts Forums
How many?
Old 07-29-2010, 09:34 PM
uturrrn2 uturrrn2 is offline
uturrrn2 is starting off with a positive reputation.
How many?
Does anyone know (and where the information was obtained if possible) how many 1965 F100 Flareside Longbed Fords were made?
If not that specific, how many 1965 F100 Flaresides were made?
Thanks for the help in advance
Old 07-29-2010, 10:29 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
34,184total F100 Flaresides...there was no breakdown for long or shortbed trucks or 2 or 4WD trucks either...
This is from The Standard Catalog of Light Duty Ford Trucks 1905-2002 by John Gunnell written in 2003....
- cs65
Old 07-29-2010, 10:39 PM
66crawler 66crawler is offline
66crawler is gaining momentum as a positive member of FTE.
34,184 flare sides.
Old 07-29-2010, 10:53 PM
Wow. You guys are great- thanks alot yall for the quick responses!
Any estimates on how many are left?
Old 07-29-2010, 10:57 PM
1/2 ton flaresides...not too many given these were farm trucks and used hard ...prolly less then 10K but thats totally a guess pulled out of the air...
- cs65
Old 07-29-2010, 11:40 PM
If it helps at all, in 66 there was only 839 4x4 flair sides produced.
Old 07-30-2010, 10:03 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 66crawler View Post
If it helps at all, in 66 there was only 839 F100 4WD Flaresides produced.
1965 F100 production figures do not break down to how many were 2WD or 4WD. All that is listed is how many were Flaresides (34,184) or Stylesides (178,581).
1966 is a different story as both 2WD & 4WD Flareside and Styleside production figures are available (ditto for F250 2WD/4WD and F350).
Additional 1966 F100 4WD production figures: Chassis & Cab: 145 / Styleside Pickup: 4,493.
The survival rate for 1960's vehicles is 10%. Y'all can do the math.
The Standard Catalog of Light Duty Ford Trucks -1905/2002 / by John Gunnell / krause.com / ISBN: 0-87349-411-3.
It's out of print.
Old 07-30-2010, 10:11 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
I want to find that half of a chassis cab!
Old 07-31-2010, 03:50 AM
Quote:
Chassis & Cab refers to a truck without any back of cab equipment.
No pickup bed, no nothing was installed, all that's behind the cab are bare frame rails.
When customers want to install special back of cab equiment like a wrecker or utility body, box van or whatever...they buy a Chassis & Cab.
Did'ja know that Ford also offered two different types of Open Drive-Away's?
Chassis & Cowl and Chassis & Windshield, and I'll betcha you've seen at least one of these styles.
Ice Cream trucks (Good Humor, for example) were usually Cowl and Windshields...had no cab at all.
Both are pictured on page 69 in the General Informatiion Section of the '64/72 truck parts catalog.
Old 07-31-2010, 06:33 AM
I was doing math ND. 145x0.10=14.5
So somewhere there is a half a truck!
Trying to be funny and failed.
Old 07-31-2010, 10:33 AM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Sailed right past at warp speed.....
Garbz
1965 F100 Flareside Spare Tire Bracket & Fender johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 23 03-25-2014 12:37 PM
1965 Ford F100 gas tank Invader6 1961 - 1966 F-100 & Larger F-Series Trucks 6 12-13-2011 08:15 PM
1965 ford ranger subaholic79 1961 - 1966 F-100 & Larger F-Series Trucks 22 03-19-2011 06:35 PM
How many gallons is the stock gas tank on a 1965 F100 1965TwinIBeam 1961 - 1966 F-100 & Larger F-Series Trucks 9 02-12-2009 09:56 PM
production numbers 9flareside3 1987 - 1996 F150 & Larger F-Series Trucks 1 07-28-2006 09:44 PM
Tags
1966, 2010, built, f100, f150, ford, produced, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
