I have some questions about my 262 inline six
Not sure this is the right place, but I have a 63 F100 with inline 6 262. I recently installed new coil, new points, new spark plugs, new wires, dist. rotor and cap, as well as vacuum advance. It has a single barrel Holley carb. It will run just fine in the garage and I can rev the engine OK. It hesitates slightly during acceleration. I set the timing at 10 deg as that seems to run good.
The problem happens when I drive about 1 mile and then all of the sudden, POP, sputter, POP sputter, and massive loss of running power. It will idle OK, but if I try to rev the engine it just about dies. I was able to limp it home. When I got home, and idling, I checked the voltages (14V at the battery when idling, and 10.2 V at the ignition coil). I am thinking it's fuel as the original tank is in the truck. I replaced the rubber sections, but not the hard lines. Maybe it's getting fuel starved? Any other ideas?
Thanks,
David.
Thanks,
David.
From what I can tell the bottom of the tank looks ok, but brownish. I installed a new fuel filter maybe I will pull it and see if there's crud. The timing advance is hard lined to the carb. I just replaced the vacuum advance unit and checked it. It holds a vacuum at the connection to the carb.
I just realized that when I set the timing, the vacuum line was still attached. Should I pull it off when setting timing?
bg_
18
02-26-2015 04:31 PM
999yards
24
09-26-2012 10:47 PM
