Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-29-2010, 05:14 PM
kbakerc kbakerc is offline
Garage is empty, add now
kbakerc is starting off with a positive reputation.
1979 Ranchero door latch
I have encountered a problem I am not certain how to solve. Both of my doors will not fully latch. The latch will catch when I manipulated the latch mechanism but will not fully latch so the doors are completely closed. Any suggestions for solutions will be greatly appreciated.
Thanks, Ken kbakerc@unm.edu
  #2 (permalink)
Old 07-30-2010, 07:22 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Look at the striker plate, it has a nylon bushing on it. When it cracks, and/or falls off, the door will not latch properly.
The striker plate can work loose. If that occurs, in order to open the door from the outside...push the door inwards as far at it will go.
Then when its fully in that position, raise the handle.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 07-30-2010, 07:38 AM
Many thanks. I will attempt to fix this problem and see what happens. Ken
  #4 (permalink)
Old 07-30-2010, 07:54 AM
Ford Parts Guru
2013 Ford Escape
The nylon bushing is not available by itself, only comes with the striker. Regardless, the way Ford made the striker, there is no way to replace just the bushing.
Ford used the same striker plate (D2AZ6522008A) from 1972 thru the 1990's on darn near every vehicle. Right/left is the same, front/rear is the same on 4 doors.
It's available from Ford, and can be bought at autoparts stores. At wrecking yards, get the strikers off the rear door posts of 1972 and later LTD/Crown Vic/Merc Marquis/Grand Marquis, as they see very little usage compared to front doors.
__________________
  #5 (permalink)
Old 07-30-2010, 02:59 PM
Thanks
WOW- you are really helpful and I really do appreciate your assistance. Will follow your advice.
many thanks, Ken
  #6 (permalink)
Old 07-30-2010, 09:18 PM
fl1a fl1a is offline
fl1a is starting off with a positive reputation.
The red carded Motormite HELP brand strikers worked for me. Bring an old one along to compare length.
  #7 (permalink)
Old 08-12-2010, 10:32 AM
Finally received new door strikers for both doors and installed them - doors close perfectly but I see that my passenger door on the '79 Ranchero is sagging. Any hints on approaching the repair process to correct this?
Again, many thanks for the information,
Ken Baker
  #8 (permalink)
Old 09-30-2010, 06:36 PM
htrdr htrdr is offline
htrdr is starting off with a positive reputation.
To repair the sagging door(s) you will need to replace the door hinges or at least the door hinge pins and bushings. Check with parts guy ed for prices and availability.
Dan.
  #9 (permalink)
Old 09-30-2010, 07:39 PM
Smile Ranchero door
Thanks for the insight and will give it a shot to see what happens. Many thanks, Ken
  #10 (permalink)
Old 10-01-2010, 08:18 AM
Ford Parts Guru
2013 Ford Escape
Quote:
Dan.
PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Tukwila WA-as you know ) will not be able to help with the hinges, since they are obsolete.
The hinge pins (B9A5943030AA) & bushings (D1AZ6522841A) are still available.
D2OZ6522800A .. Upper Door Hinge / Right/Left is the same / Obsolete
Fits: 1972/76 Torino/Ranchero/Thunderbird/Montego/Mark IV / 1974/78 Mustang II / 1974/79 Cougar / 1977/79 LTD II/Ranchero/Thunderbird/Mark V.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 607-722-5371.
JST AUTOMOTIVE in Lebanon TN has FIVE = 615-443-3086.
D2OZ6522810A .. Lower Door Hinge / Right/Left is the same / Obsolete
Fits: Same as above except does not fit Mustang II.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
PEROGIE ENTERPRISES in Highstown NJ has ONE = 609-448-1684.
JST AUTOMOTIVE has TWO.
Before buying anything, try the following which is an old used car dealers trick for fixing sagging doors.
Get a 2 x 4 about 5 ft long, lay one end midway along the door sill, t'other end on hard flat surface ground. Close the door till it just touches the wood then...give the door a slight push.
Now close the door, see if it still sags...if so, repeat the process till the door closes correctly.
Tighten up the hinge bolts afterwards. Do NOT do anything with the bolts beforehand.
__________________
Tags
1990, 50, 79, bushing, d2oz6522800a, d2oz6522810a, door, f150, ford, latch, mustang, plate, ranchero, replace, striker, tightening
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
