1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 f250 abs light flashes/speedo bounces around???HELP!
Old 07-29-2010, 07:08 AM
chris7678's Avatar
chris7678
chris7678 is offline
My truck seems to be idling okay. While driving my idle is rough while accelerating and my abs light starts flashing and my speedometer bounces around. These 3 things all started at once and there is not an engine light on...Help!!!!
Old 07-29-2010, 07:16 AM
greenego's Avatar
greenego
greenego is offline
It sounds like the VSS sensor located on top of the rear differential is failing. I just recently replaced mine on an 01 f250 with the same symptoms and all has been well since then.
Old 07-29-2010, 08:40 AM
VAXB's Avatar
VAXB
VAXB is offline
Mine has done this since I loaded my tuner. It never did it before, and only does it under full throttle. Doesn't seem to affect anything and like you said no codes. Would the tuner affect the VSS sensor?
Old 07-30-2010, 01:18 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
chris7678, that definitely sounds like the VSS on the rear differential.
VAXB, that's STRANGE. What engine/year/etc?
SSirois
1997-2006 Expedition & Navigator
09-20-2017 08:37 AM
Jtstein98
04-12-2017 02:51 PM
Hotairjunkie
10-11-2016 07:43 PM
tjc transport
27
12-06-2015 07:48 PM
F0rdF0rever
11-15-2003 11:22 AM
Quick Reply: 2002 f250 abs light flashes/speedo bounces around???HELP!
