2002 f250 abs light flashes/speedo bounces around???HELP! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-29-2010, 07:08 AM
chris7678 chris7678 is offline
chris7678 is starting off with a positive reputation.
My truck seems to be idling okay. While driving my idle is rough while accelerating and my abs light starts flashing and my speedometer bounces around. These 3 things all started at once and there is not an engine light on...Help!!!!
Old 07-29-2010, 07:16 AM
greenego greenego is offline
greenego is gaining momentum as a positive member of FTE.
It sounds like the VSS sensor located on top of the rear differential is failing. I just recently replaced mine on an 01 f250 with the same symptoms and all has been well since then.
Old 07-29-2010, 08:40 AM
VAXB VAXB is offline
VAXB is starting off with a positive reputation.
Mine has done this since I loaded my tuner. It never did it before, and only does it under full throttle. Doesn't seem to affect anything and like you said no codes. Would the tuner affect the VSS sensor?
Old 07-30-2010, 01:18 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
chris7678, that definitely sounds like the VSS on the rear differential.
VAXB, that's STRANGE. What engine/year/etc?
02 ABS light and bouncing speedometer. tjc transport 1999 - 2003 7.3L Power Stroke Diesel 27 12-06-2015 07:48 PM
02 ABS/speedometer issue tjc transport 1999 to 2016 Super Duty 6 05-18-2015 12:01 PM
ABS LIGHT ON ANd 4WD LIGHT FLASHING rickfar Escape & Escape Hybrid 55 01-15-2012 11:33 AM
ABS wheel speed sensor magneto259 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-10-2009 06:37 PM
ABS Light flashing code16 -- okay? jeremyibe 1987 - 1996 F150 & Larger F-Series Trucks 1 08-20-2002 05:16 PM
Tags
2002, abs, accelerating, bounces, duty, engine, f250, f350, flashes, flashing, ford, light, rough, speedometer, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
