my first 4.9L rebuild
so my bro in law and i have started tearing into his 4.9 and we're wanting to get a little more power and fuel economyout of it. so far we've decide to put a comp cams cam in it most likely and boring it .030 over. gonna do an electric fan. maybe a t body. would the t body be necessary for this small of a build? what compression ratio are the 4.9s in 95? by the look of the pistons and combustion chambers it doesn't look like it could be much...... also what pistons and cam do you recommend to run? i think this thing needs at least 9:1 compression ratio. thanks in advance for any help!
The combustion chamber on the EFI head won't stand much if any polishing as this screws up the fast-burn characteristic of the EFI head. Port runners can be cleaned up a little though. A 3-angle valve job and a 30* back cut on the intake valves doesn't hurt a thing.
IIRC Isky has two cams that are computer compatible. Do a search in their catalog for them.
Hypereutectic pistons are better than stock cast pistons for very little more $$ and are available in stock configuration.
i would leave the t body be on this honestly. have you considered a good port and polish on the head.? ive heard this little mod works wonders. the 300 can also unleash its inner beast once you let it breath. do a decent exhaust and ditch those two restrictive cats on there.
dashman
03-20-2019 10:06 AM
dylansf23
18
04-26-2014 09:51 PM
jonezzzman
07-31-2013 10:22 AM
7636074460
05-07-2012 08:58 AM
RoadRash
05-21-2003 05:42 PM
1983, 49, 49l, combustion, compression, engine, f150, ford, inlin, job, liter, performance, ratio, rebuild, rebuilding, test, valve
