3 speed manual column shifter - Ford Truck Enthusiasts Forums
Old 07-28-2010, 09:47 PM
eels67 eels67 is offline
eels67 is starting off with a positive reputation.
Hello,
I just bought a 67 f100 with a 3 speed on the column and it's having trouble shifting from 1st to 2nd. I understand this is a common problem, but I'm new to this kind of thing, so can someone tell me how to fix the problem?
Thanks so much,
Darrin
Old 07-28-2010, 10:08 PM
Ooftus Ooftus is offline
Ooftus is starting off with a positive reputation.
Linkage
Check to see if your shift linkage might be binding..............
Old 07-29-2010, 08:13 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Darrin, Pull the shift lever towards the steering wheel, and almost go to reverse before letting it go down in neutral and lifting into 2nd.
That method used to work for me, then I put in a C6 and stopped all that nonsense.
John
Old 07-29-2010, 09:00 AM
Thanks!
Thanks for the help guys. I have been doing what you said John with sliding the shifter right up the steering wheel and letting it "pop" out of first before putting in second, but last night I was going up a hill and trying to shift into second and I guess I was in a hurry and the shifter was just loose between gears and the truck was still in first. I had to stop the truck and get under it to get the shifter loose. I guess I'm wondering if there's a rebuild I need to do or is this just part of the column shift. Thanks again!
Darrin
Old 07-29-2010, 09:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
The shift lever binding up between 1st and 2nd gear is a very common problem with these trucks.
At the bottom of the steering column under the hood are the two manual control selector levers the shift rods from the transmission attach to.
In each lever is a rubber bushing and insulator. The rubber bushings harden up, age crack, break apart, causing the shift lever to bind up.
C5TZ7343A .. Bushing & Insulator Kit-This kit does both levers.
Ford just obsoleted this kit, but there are 146 still available at Ford Dealers/obsolete parts vendors.
Fits: 1965/72 F100/350 & 1973/79 F100/150 with 3 Speed Manual Transmission.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
TISON MOTOR CO in Estill SC has 3 = 803-625-2551.
JST AUTOMOTIVE in Lebanon TN has 5 = 615-443-3086.
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 37 = 888-727-0418.
Old 07-29-2010, 10:50 AM
Thanks!
Thanks so much Bill!! I'll look into getting the kit!
Starting on my 67 broncohog 1967 - 1972 F-100 & Larger F-Series Trucks 96 09-12-2015 07:45 AM
Lower steering column coupler on 67 F250 Mikes67F250 1967 - 1972 F-100 & Larger F-Series Trucks 12 02-03-2015 07:36 AM
Column shift AOD hch60 1957 - 1960 F100 & Larger F-Series Trucks 4 12-27-2014 12:33 PM
need a steering column extension pinkpanther 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-24-2014 07:12 PM
54 F100 changing the steering column Silent Thunder 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 03-29-2014 08:57 PM
Tags
1969, 1972, 3speed, automatic, colum, column, custom, f100, f150, ford, manual, shift, shifter, speed, sport, standard, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
