Ranch Hand Grill Guard installation???
Anything special I should know before tackling the installation of a Ranch Hand Grill Guard? I bought it used with NO mounting hardware...just the grill guard. I have tow hooks and want to retain them. I see the tabs for the tow hooks. Do I need any special hardware or brackets etc.? Will I reuse the existing OEM bumper bolts? Are they long enough? Any time saving tricks etc.? Help!
2003 F250 CC 4x4
2003 F250 CC 4x4
Thanks...yes, I'll keep my fog lights. However, there are 3 bolt locations on each side...1 is hidden by a factory plate that needs to be removed? My factory tow hooks will bolt on to the grill guard. I'm just really interested in the 3rd bolt location...what size / type of bolt should I get?
I'm looking for a rear replacement with backup lights that will allow me to retain the factory hitch. Top Gun comes well recommended, but I haven't been able to find out yet if I would lose my factory hitch or not?
Hello, I installed a Ranch-Hand Grille Guard not too long ago by myself and it was easy. I used a 'come-along' hoist from harbor freight and attached it to a rafter in the garage using a chain to give the proper length. I then removed the two bolts that hold each tow-hook and removed them. The two nuts of the tow-hook bolts will fall out from the back...they are joined together by a piece of sheet metal. The truck's bumper will loosen and will not fall off since it has other brackets behind it attaching it to the frame. The truck's bumper will move up and down slightly. Lift your Ranch-Hand, place the tow-hook on top of the guard's "L" bracket, line up the holes and insert the bolts making sure the nuts are behind it. Make sure everything is aligned and torque your bolts. The entire process took about an hour by doing this my myself.
Are we talking full front replacement or just a grill guard? A grill guard is only 120 pounds or so and will only require a couple of people. A full replacement will be 250+ pounds and require a few more. The grill guard will not interfere with tow hooks at all and on the full front end, they will bolt to the actual unit.
Jayft8 - I had a Top Gun rear on my Chevy and I got an 8" drop which will allow you to retain your factory hitch. Don't get more than 8" if you want to use your hitch.
I really gotta have the backup lights and that's a sticking point on what I can get (I can't hardly see at night anymore) - I've got some time today and I'm going to go by my local dealer to see what we can come up with for me to order.
I'll be sure and post a pic for you once I get it installed.
. . . hey wait a minute? you don't work for Top Gun, do you? . . . hah! just kidding
Originally Posted by Top Gun Bumper's Website
Please Note: All 2” Receiver Tubes that are welded in our Front Bumper Replacements and Bullnose Bumpers ARE NOT designed for Winch applications, come-alongs, etc. of any kind. They are designed for general use purposes only, not for high stress applications that include any heavy pulling. TGI Corporation assumes no responsibility and warranty shall be voided if used in any manner for which it was not designed.
Originally Posted by Ranch Hand's Website
Our standard front ends and Bullnose front ends have a 2” receiver for use with a removable winch cradle.
I got quoted $1450 installed for a Top Gun, no winch, just the receiver tube, and $1050 installed/$950 out the door for a Ranch Hand Legend. That's a decision I really had to ponder for a whileCall me a brand ***** if you want, but I just bought the better known, arguably better built, AND cheaper bumper.
I'm getting this one installed for me because I'm a vagabond moving between 3 places in 2 months, but it's not hard. Use an engine hoist for the install, I had a cheap harbor freight lift I used to move a welder with, and it's held up several grille guards I've done on 150s. It held a 700# welder far enough out to back a trailer under it, ~300# of bumper is nothing for it.
I have had both and can tell you that construction wise the Top Gun is better. I would imagine that the disclaimer is there so that they don't have to replace bumpers by warranty because someone did something stupid. Ranch Hand is a larger company and can better afford replacements if you happen to pull something too heavy.
"Don't kill stupid people, just take all the warning labels off and the problem will fix itself."
try not to shoot me too full o' holes there Red Raider
for the record - I'm looking for a rear bumper that will allow me to retain the use of my factory hitch
Ok, too many people have names starting with 'J' in this thread, and I got confused. I thought 'jayft8' was the OP talking about a front end, and that 'jc8825' and 'jdc228' were the same person. I'm caught back up now, I thought we were still on grille guards, my bad.
hm . . . I've always wanted to change my name to Elvis . . .
I ordered my ranch hand grill guard online from Built For Trucks and installed pretty easy and it came with the bolts and instructions. Price was good got for under $500.
kalebc2
08-06-2015 10:05 PM
