460 vs. 454
#121
#122
Where oh where did our buddy 6.6 go? Must be a lot of hay needs cutting........Engines have really progressed since those "dark" days,Dave! Plenty of small 4 cylinders make 165 Hp these days,and nowadays a 200 Hp 6 cyl. is considered underpowered,and most of the competitive V8's are making at least 275 Hp,with lots pushing quite a bit more.....Of course,even if that old 454 only put out 20-25% more hp than some 4 cylinders,it still had pretty good torque #'s........
#123
Totally off the topic,as far as engines go,but i will admit im rather impressed with how heavily my newest addition to the Fleet,an 80 Chevy K20 has its rear leaf springs set-up...After all,the old Highboys arent exactly softly sprung,i went out in the driveway and the 72/75 has 8 rear leaves,probably a 2-3/4- 3" stack,on top of a 4" block. The Chevy has NO rear blocks,but a 4" thick stack of 11 main leaves,with a set of 5 leaf overloads,and it appears factory! I would assume this has to do with GVW,as the Chevy is at 8600 lbs,and i seem to recall that max GVW for a 75 F250 4x4 is at around 7700 lbs
#124
#125
6.6 liter is defending one of the worst POS engines GM ever put out, the stock SBC 400 chev. will never be known for much more than overheating, warped castings and cracked cyl. heads. The 350 or the 402 BB were far better motors.........I dont know, Bob maybe 6.6 took the same writing class as Shipboy.
The following users liked this post:
#126
#127
#128
THe First 4 trucks i ever owned were all either 1970 or 1968 GMC's,a 70 1/2ton 2wd Suburban with a 292 6cyl,and a 4 speed(great torque,esp. at low rpm) a 70 3/4t 2wd w/ a 327,and a 4spd( fairly Quick),a 70 3/4t 2wd w/a 350/Turbo350(probably quicker than the 454 powered Monte Carlo) and a 68 3/4 4wd w/ a 327 4spd and 4.56 gears(not quick,no top end thanks to 4.56 gears,HARD riding,potentially thumb and wrist breaking thanks to manual steering,but it was fun off road). In the years since ive owned a little of everything,last time i tried adding them all up on a sheet of paper,i counted 35 total cars and trucks,of which only 4 havent been either pickups or SUV's....
#129
Flyin is about what it'll do if you get the optional 3.92 rearend. As for the heavy leaf springs, I was considering it for my F-350 but then I figured I'd make a field repair truck out of it. Throw an air compressor on the motor, put airbags in it for the gooseneck, put tanks on it for running an impact and air jack... That ought to shorten up the work day, then I wouldn't be stuck out in the field all day makin hay like some illiterate 400 SBC connesseur.
#130
Tell ya what Dave,if i manage to make it up your way one of these days,i will let you know ahead of time,and maybe we can get together for a Beer,i seem to recall a brewery or two in the Eugene/Springfield area,probably one of the McMenamins.....My ex-wife and i made a road trip up thru Oregon in 2002 for two weeks and loved it,and my Current wife and i took our Honeymoon trip up thru your Beautiful state in october 2007,and enjoyed it a bunch. Nice people in your state,we noticed that Oregon's liberals are typically less angry than are California's......oops,Admin,i will avoid the dreaded "P" word in this area,dont wish to get this rather entertaining thread tossed
#131
#133
Sounds great, Bob!..........Mc Menamins is pretty lib/ yuppie, good food but kinda uptight.
I can steer you to some other watering holes that you might feel even more comfortable in!..................Bring your pole October is the middle of salmon season on the rivers!...You will have a free guide!
#135
Lake creek RFD is about 50 miles west of me in the coast range, VERY rural, beautiful country with a great salmon/ steel head run on the Siuslaw river.......The area Ken Kesey wrote about in "once a great notion"....(Never give an inch) movie with Peter Fonda about loggers.
