1959 ford f100 with a 302 or a 351??? - Ford Truck Enthusiasts Forums
Old 07-28-2010, 06:25 PM
glmule glmule is offline
glmule is starting off with a positive reputation.
recently bought a 1959 ford f100 with we are sure what. what is the best way to tell the difference between a 302 and a 351? are there some numbers on the motor that i should look for or is it more of the size of valve cover or what? HELP!!!
Old 07-28-2010, 08:13 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
First, we need to know which 351 we're talking about. There's 3 different ones to choose from. The Windsor looks just like a 302, only wider across the intake manifold from the taller deck height. The Cleveland has larger valve covers with 8 bolts (6 bolts on the windsor) and a water neck that sticks straight up from the front of the block, as opposed to coming out of the front of the intake like the 351W/302. Here's the confusing part. The 351M looks just like the 351C, only again with a taller deck height and wider intake manifold. If you can post pictures, and measure the width of the intake, that would help us help you with the identification.
351W
351C
Old 07-29-2010, 01:47 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Mule,are you sure you don't have a Y-block?Where is the distributor located?
Old 07-30-2010, 12:11 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
a quick visual clue is to look at the block beside the distributor. the 351W has a reinforcing rib while the 302 doesn't. there is also the same reicnforcing rib at the back of the block. another visual clus is that on the 302 the lower bolts on the thermostat housing are hidden behind the water pump while they are more exposed on the 351W sue to the taller deck height.
rgds
Mike
Old 07-30-2010, 12:48 PM
ibuzzard's Avatar
My Y block has it's distributor near the fire-wall on the passenger side.
1959 f100 frame swap 86ford94 1957 - 1960 F100 & Larger F-Series Trucks 6 02-18-2016 04:48 PM
1960 vs 1959 Ford F100 Vsanzbajo 1957 - 1960 F100 & Larger F-Series Trucks 22 02-02-2015 10:10 PM
1959 f100 292 engine swap pagokid2001 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-15-2010 12:43 AM
1976 inline 300 swap in 1959 f100 rodriguezfords Ford Inline Six, 200, 250, 4.9L / 300 1 03-22-2008 08:31 AM
Ford f100 1959 rodriguezfords 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 02-15-2008 11:24 AM
Tags
12, 1959, 1983, 302, 351, 59, block, deisil, engine, f100, ford, identification, install, pictures, small, truck, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
