help with driveshaft please
Old 07-28-2010, 03:18 PM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
please help me with my driveshaft please, my rear u joint thats closest to the differential has play in it, also I'm not sure if these are bad carrier bearing tests but I put the truck in neutral, park brake on, and grabbed the drive shaft near the carrier and moved it up and down and I can see the yoke moving up and down and clunking, so I know for the u joint I'll need my torx bits, then do I just pull the shaft out from the transfer case? I do not have a shop press to get the joint out though
Old 07-28-2010, 04:57 PM
kenpobuck's Avatar
kenpobuck
kenpobuck is offline
I don't know much about the carrier bearing part sorry. But you can swap the joints with a c-clamp or benchvise. Find a socket that the cup will fit into but will seat against the yoke. For the other side find a socket hat is a little smaller than the cup. Put the sockets and the yoke in the clamp/vise and press them out. Then place the joint in the empty yoke and the cups in the holes makeing sure the needle bearings stay in place and press them in till flush. Then take the smaller socket and press he cups in till you can get the clip in the groove. Don't go to far or it will bind the joint. Install and grease. I have done this with a hammer instead of clamp/vise along the roadside and on the trail lol.
Old 07-28-2010, 05:45 PM
powerstroker100
oh okay, do you think this u joint and the other bearing could be the reason why the truck has the annoying vibration I've been trying to figure out?
Old 07-28-2010, 06:02 PM
kenpobuck's Avatar
kenpobuck
Ya it will do that lol. It is a cheap fix as well. Did you do a search to find out how to remove the carrier bearing?
Old 07-28-2010, 06:07 PM
powerstroker100
not yet I actually just watched a video on replacing u joints on the drve shaft with the vice and socket method you told me about, it seems pretty easy, now I need to figure the carrier bearing funny business, also is there a special torque for the drive shaft bolts, I do not want it flying off on me, yikes lol
Old 07-28-2010, 09:42 PM
powerstroker100
well I cant find a how to on the carrier bearing so I'm just going to dive in head first and figure it out, however I don't know what bearing I need, looking on napa theres a few different designs most have a strange support on them and doesnt look like anything I saw today under the truck
Old 07-28-2010, 09:56 PM
poocher pup's Avatar
poocher pup
poocher pup is offline
sanding the SURFACE rust off of the driveshaft will make changing carrier bearing easier. job is not fun and really depends on tools you have as the best way to remove and replace it.
Old 07-28-2010, 10:14 PM
powerstroker100
what kind of tools are needed?
Old 07-28-2010, 10:46 PM
powerstroker100
ahh, I've been reading about needing a press to get the old bearing out and the new one in, I saw a method on cutting the old bearing then hitting with a chisel to pop it off which I know that I can do but then will I be able to get the new bearing on without a press
Old 07-29-2010, 02:16 AM
powerstroker100
bump anybody done this carrier bearing swap before? also whatsize bearing is it I see two when I look for parts?
Old 07-29-2010, 06:39 AM
iron1951's Avatar
iron1951
iron1951 is offline
I have used the cut and chisel method to get the bearing off. I had a friend make a tool by welding the old inner race on a piece of pipe and used that to put the new bearing on. Did clean up the rust first. Had no problem getting the new bearing on.
Old 07-29-2010, 07:47 AM
powerstroker100
hmm alright, thank you for the input I think if I go to the auto store they could find on there computers what bearing size is correct for my rig
Old 07-29-2010, 04:55 PM
powerstroker100
well got the joints in, left the carrier alone theres about 2mm of play in it so I figured its so small it must be normal?? who knows? ofcourse my 50mph vibration is still here, this is so frustrating I'm ready to get rid of this truck, I looked at the tranny mount and it looks fine crossmember that its on looks fine aswell, found a heatshield that was dangling and hitting the the transfer case so I zip tied that back up other than that I'm at wits end
Old 07-29-2010, 05:35 PM
iron1951's Avatar
iron1951
iron1951 is offline
Does the vibration go away at a higher speed, like 60 mph? My truck is like that but more noise than vibration. When I gave you my tip, I was talking about the hangar bearing, the one that supports the two piece drive shaft.
Old 07-29-2010, 05:59 PM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
Did you phase your driveshaft?
From the '93 FSM:
Quick Reply: help with driveshaft please
