Ultimate Mustang Mod Motor - 5.5L BB Stroker Race engine - Ford Truck Enthusiasts Forums
All Other Items for Sale All other items (non Ford Truck related) for sale. Tools for the garage, brake pads for your 66 Mustang and your beer fridge go here.
Old 07-28-2010, 02:02 PM
hkaiser83 hkaiser83 is online now
hkaiser83 is gaining momentum as a positive member of FTE.hkaiser83 is gaining momentum as a positive member of FTE.
This motor has been under construction since December of 09 and I've honestly lost interest. I don't have the ***** to go fast enough to even take advantage of this motor so I don't know what I was thinking.
Teksid block with Darton MID "Wet" sleeves
Block was Honed (3 stage - cooling between passes), decked, align honed
Sonny Bryant Billet stroker crankshaft
Oliver Billet rods with ARP2000 rod bolts
Custom L&M Spec Diamond pistons - extra thick ring lands and dome thickness
Total Seal ringset
Clevite H bearings - polydyn coated
Melling Billet Oil pump
Cometic head gaskets
all new seals
entire rotating assembly balanced within 1g
balanced by shaving, not drilling
Polydyn coated crank, rods, oil pan, and piston crown.
Heads were done by Modular Head Shop and are considered a Stage 3 port
Flow 330 intake and 275 exhaust
1mm oversized ferrera valves
Crower High Load blower valve springs
combustion chamber size has been matched to 3.7 bore size
Bullet Racing custom cams
Polydyn coated combustion chamber and exhaust ports
New timing assembly as well.
As a side note, the cams have not been made yet and I'm going to wait on having them made for a few weeks to see if any serious buyers step up. This just means I can have them design the cams specifically for the buyer.
Have $16,000 in receipts for this engine. I was owed a huge favor by the engine builder so he charged me his cost on the machine work, cheap assembly, and his cost on parts. That means if you tried this engine on your own you would pay probably closer to $20,000.
$14,000 obo + shipping
2001 7.3 Powerstroke - Custom Build 400-450HP 7.3 PStroke 1999 - 2003 7.3L Power Stroke Diesel 46 08-09-2016 07:48 AM
To Hone or Not? Help please KIKKUP 1973 - 1979 F-100 & Larger F-Series Trucks 15 07-01-2013 08:48 PM
big inch 400 . . . mustange70 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 07-21-2010 11:39 PM
Looking for More HP for my 545 . . . F350 Strait Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 05-17-2010 01:21 PM
Break in precedure??? FordManStan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 12-31-2006 10:07 PM
Tags
1997, 54l, billet, bryant, crank, crankshaft, ford, kits, modular, mustang, rods, sale, sonny, stroker, ultimate, v8, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
