2010 F150 Remote Start - Ford Truck Enthusiasts Forums
Old 07-28-2010, 11:33 AM
jerryrwoods jerryrwoods is offline
jerryrwoods is starting off with a positive reputation.
I just bought a new 2010 F150 and it came with the factory remote start with the separate key fob. Does anyone know if I can get one of the integrated key fobs and program it to my truck/starter? Also if that is possible where can I get one?
Jerry
Old 07-28-2010, 02:32 PM
SteveVFX4 SteveVFX4 is offline
SteveVFX4 is starting off with a positive reputation.
you won't be able to use an intergrated key to control the remote start, but if you want to get rid of the keyless entry fob, then I've read about other guys using the Ford Fusion key or some other flip-style key from ebay. They have the intergrated lock/unlock buttons, and then you just attached the remote start fob to that.
Old 07-28-2010, 02:40 PM
just to be clear....
Maybe I shouldnt call it an integrated key fob.... What I mean is the 6 button key fob with remote start and door lock/unlock, or maybe even an older style 4 button.
Jerry
Old 07-28-2010, 03:10 PM
oh, I thought you meant the intergrated "key" so you didn't have to carry any fobs around.
I'm not sure those other style remotes will work for you. From what I see on the wiring diagram/harness for the 1-button system, it does not even tap into the truck's door unlock wire. So maybe they would work and could start your truck and lock the doors, but you wouldn't be able to unlock the doors with the fob.
I have the 6-button alarm/rmst fob right now on my 09. I know the older 4-button rmst fob you are talking about. I was actually thinking about trying to program that 4-button fob for my truck because I don't really care for the 6-button fob. I hope to get one from my installer later this week and will give it a try. His guess is that he doesn't think it will work for me.
also, unless your installer/dealer already fixed this, you'll want to change the option setting for your system so it doesn't shutoff everytime you open the door after remote starting (due to the new 2010 My-Key feature). You can find the option settings in this file, you'll want to change Option Bank 2, Option 7 on page 2 of this file:
http://documents.codesystems.com/710620.pdf
Old 07-28-2010, 10:44 PM
Well.... now I did it.
Well... I fixed her up good. I tried to adjust setting 7 in bank 2, but now the remote start does not work. I get one chirp like normal, then 4 chirps which I think means the tach signal is messed up. Any Idea how to fix that?
Jerry
Old 07-29-2010, 12:43 PM
uh-oh, you did it now. During the programming, did you mistakenly hold-in the rmst button for longer than 3 seconds because that resets all of the options?
my only suggestion is to check the Option Bank 2, Setting 1 to see if you are set for Tachless operation (LED on for that setting). Our rmst systems do work without having to tap into the tach wire, so that option should be set for Tachless.
Old 07-29-2010, 08:05 PM
lou1947 lou1947 is offline
lou1947 is starting off with a positive reputation.
the 2011 250 have an integrated door key and remote. Hopefully the remote start is also on the key.
Old 07-30-2010, 05:15 PM
Thanks
Thanks for your help! I figured out the led that the procedure is talking about is behind the panel under the steering wheel. Once I could see that I figured out I had the starter set for tach mode. Turned that to tachless and now it works great! I also fixed the mykey problem.
Jerry
Old 07-30-2010, 09:22 PM
glad you fixed it. yeah, I forgot to mention that they usually don't mount the LED light or the black program button so you have to go find it under the dash/steering panel.
Old 11-27-2011, 07:25 PM
delirious delirious is offline
delirious is starting off with a positive reputation.
sorry to dig up this old thread but I accidently reset the remote start by holding down the key over 3 seconds. I am getting the four horn beeps when trying to start the truck.
I didn't realize the red led was under the dash and I kept thinking it was on the keypad. Anyways, I know you have to set the tach option in bank 2 to tachless but it isn't working. After I set the option, I turn off the key to the truck but I don't think this is causing the option to stick. Once you program the option to tachless, what do you do to make sure the option stays? I don't see anything in the instructions that tells you what to do once programming is finished. Thanks for your help.
Old 12-17-2011, 09:58 AM
sassydog sassydog is offline
sassydog is starting off with a positive reputation.
run time
Quote:
steve is it possiple to extend the run time on the 2010 xlt factory installed remote start . I was told no . sassydog
Old 12-17-2011, 10:54 AM
^yes, look at the file link I posted above. Option bank 2, option 3 you can change the run time from 10 minutes (default) up to 15 minutes.
Key Fob not programming ride_red 2004 - 2008 F150 6 06-15-2015 07:22 PM
programming remote start fob IronHorsePilot 6.7L Power Stroke Diesel 23 01-05-2015 01:16 PM
2010 FX4 Alarm/Remote Start Buying Help schlim66 2009 - 2014 F150 1 11-26-2014 08:32 AM
Factory remote start doesn't work after new keys LucasMN 1997 - 2003 F150 3 10-12-2012 11:36 AM
2012 F250 keyless fob skscci 1999 to 2016 Super Duty 6 03-26-2012 05:14 PM
Tags
2010, button, f150, ford, harness, integrated, key, keyless, option, platnum, remote, start, starter, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
