1985 E350 Cargo Van No Fuel
Hey guys set my truck on fire with starting fluid. YouTube missed a great opportunity, anyway I have no fuel to this beast. 351motor 85 econoline cargo Van.
Pulling the front tank, bought fuel pump for in the tank, wondering hoiw I can tell if it has a rail pump.
Looking for the fuel relay? Any location? Found a relay on the inner drivers fender wall but not sure if this is it. It is white and not black not others described.
Does this truck have a fuel cut off reset under the passenger kick panel?
No power to the front tank when I turn on the ignition. Rear tank did not work since long before I owned it
Any help would be appreciated. What causes the fuel reset to need to be pushed? Can't find many fuses just some down by the drivers kick panel none under the hood? Does my truck have a fuel reset? Truck will start with starting fluid then die after it burns it.
Know way of knowing if the tank switcher has gone bad. Old truck need help. Thanks again.
Can you all help me out? Thanks
Go to this thread and ask the thread starter. He has a 86 van and says he replaced the relay.
https://www.ford-trucks.com/forums/9...s-running.html
If you do not have fuel injection(I don't think you do) then you do not have a high pressure frame rail mounted pump.
Relay location
He appears to have a Van with a manual fuel pump with one tabk. Mine has the cargo conversion with dual tanks and electric pumps. I found a relay but it is not black mounted on the inner wall of the drivers under hood sidewall. I do not know what this relay does, I tried my lights and they still work. Anybody that has info I would appreciate their knowledge.
How do I test the tank selector switch?
swaybar2001
1997 - 2003 F150
11-13-2012 06:06 PM
