Quote:
Originally Posted by Lazy K
Ask the shop if they are bleeding the RABS module (if fitted on the frame rail). Otherwise I would would think the RABS module may be bad.
Yea that was the first thing I did, I was fairly sure before I even started working on it based on the way the brakes acted the rabs valve was the problem.
So I picked up fittings and a short section of line to bypass it first thing. I replaced the master after the rabs valve didn't prove to be the cause.
Picked up a couple of proportioning valves for five bucks at the bone yard down the road, no help either.
The new master cylinder pumped up just fine, the remans did not. First one not at all.
It is important the instructions in the box are followed exactly or its not going to work.
Fill half way or so with fluid, use a punch or rod to stroke piston by hand up to 1" but no more then that until the piston feel is solid and only moves 1/8" to 1/4". Then put it on the truck and bleed the system.
The calipers where in good shape and didn't leak a drop, yea had surface rust em but the rubber and slides where in good shape, replaced them and the problem was gone.
I could see them flexing a tad under pressure but can't say the replacements didn't flex less.
