Backup camera system, complete
This is a complete kit from Velvac. Comes with a 7" monitor, drop down bracket, cable and rear camera. Monitor can be mounted fixed or mounted with the optional drop down bracket included in kit and can also be configured to be used as an extra DVD monitor plugged into an existing system. The Camera is a tear drop design that is meant for installations in rear doors or tailgates that is angled downward to view the correct angle. Part numbers and WD prices are below but will sell for $350 obo shipped via ups. If you want pics I can send them to you. $350 obo shipped for a kit that would cost nearly $900 in stores.
709910 Camera $150
747865 Cable 34' $32
790587 Bracket, Monitor $63
709916 Monitor $328
Monitor Description:
7" Single-screen Monitor
All Velvac monitors are heavy duty design for heavy duty and commercial truck applications. They are built and tested to withstand extreme road conditions such as vibrations, electrostatic discharge, humidity and temperature changes and to deliver high quality images to the driver.
709910 Camera $150
709916 Monitor $328
- 7" single-screen LCD Color monitor
- Three camera (A/V) inputs
- Audio speaker with volume control
- Power 12Vdc
- Monitor dimensions 7.75" W x 5.25" H x 1.25" D
- 4-hole amps pattern mount
Hi, I would love to check this system out as I have been searching the forums lately to educate myself on the most reliable camera. I'd also like to ask why you're selling it. Thanks, Mike
E-mail...michael.j.o'brien2@navy.mil
I have a back-up camera and have been fiddling with the idea of hooking up a Harbor Freight security camera to it. The camera runs off a 110/7.5 v power supply but It should be able to run off a 12v adapter. For $39 on sale, it's worth a try. The connectors are all RCA.
They also have a 2 camera/monitor system that would probably run fine off an inverter...but the monitor is the bulky tube type. Might be able to hook it up to a DVD monitor.
Wealthk1
2017+ Super Duty
13
09-02-2016 05:16 PM
carid
11-13-2015 08:08 AM
