loud sucking noise under load - Ford Truck Enthusiasts Forums
Old 07-27-2010, 12:57 PM
excursionsthebeast excursionsthebeast is offline
excursionsthebeast is starting off with a positive reputation.
Hey guys, im a newb in the diesel world so bare with me. I have an 05 excursion 6.0 diesel and developed a problem over the weekend. I tow a camper and on the way home i started hearing a fairly loud sucking noise when i was pulling hills. It seams to do it when the turbo realy starts making power. I looked for loose pipes, holes in pipes and anything visible but found nothing. Power seems fine and no other problems seem to arrise from it. While driving it sounds central of the engine compartment so Im guessing it has something to do with the turbo. Thanks for any help.
Old 07-27-2010, 09:14 PM
Just drove around a little to listen to the noise again and it seems to start the sound as soon as the turbo starts spooling up. doesnt seem to get any louder under full throttle and still has the same power i believe. only other thing is it seemed to make a little more black smoke but that could be just me.
Old 07-27-2010, 10:16 PM
jetact's Avatar
jetact jetact is offline
jetact is starting off with a positive reputation.
Have you looked on the back of the tubes for the turbo for cracks? That is my guess. Unless your hearing the fan come on.
Old 07-27-2010, 10:21 PM
Problem has been I have been looking when its hot so kinda hard to get close to the pipes on back. Ill try to look close in the morning when its cool. I know what the fan sounds like when it kicks in even though it doesnt happen very often. So the pipe on the back of the turbo is the intake?
Old 07-27-2010, 10:24 PM
jetact's Avatar
[quote=excursionsthebeast;9156642]Problem has been I have been looking when its hot so kinda hard to get close to the pipes on back. Ill try to look close in the morning when its cool. I know what the fan sounds like when it kicks in even though it doesnt happen very often. So the pipe on the back of the turbo is the intake?[/quote
Yes that one can get a crack and the CAC tubes can get them. I had mine replaced becasue of a crack at 37,000 miles. Some people never hear the fan and when they do they are really surprised.
Old 07-27-2010, 11:32 PM
possible problem found. figured i would do some more searching while its cool and the brats are in bed. the tube coming off the turbo and going to the cooler is connected with a rubber hose. the hose has a hole in the back of it. am i right in saying it leaves the turbo in the front, goes thru the cooler and returns back to the intake? if so that would produce a loud whooshing noise? the probleem i have is it has banks stuff on it and i dont know if its ford or banks now.
Old 07-28-2010, 09:30 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke 02GrayPowerStroke is offline
02GrayPowerStroke is gaining momentum as a positive member of FTE.
That sucking is the sound of the truck sucking all of the money out of your pocket. LOL PMS
Old 07-28-2010, 08:19 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Quote:
someone beat me to it.... bahhhhh
no really more then likly its the tube. if its blue in color its more then likly to be a ford part.
P1211 & P1280 and 40psi fuel pressure SaintITC 1999 - 2003 7.3L Power Stroke Diesel 21 06-16-2015 03:26 PM
If you're bored IHateCommieCars 6.0L Power Stroke Diesel 18 05-24-2015 06:31 PM
6.4 litre diesel turbo issues Donbarn 6.4L Power Stroke Diesel 3 04-30-2015 01:54 PM
7.3 turbo siren!!! BigGreen7.3swap 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-28-2014 11:13 PM
99 7.3 turbo problem diebog 1999 - 2003 7.3L Power Stroke Diesel 3 06-04-2010 08:41 AM
Tags
1996, 60, diesel, f350, ford, load, loud, makes, makinking, noise, powerstroke, problems, sound, sucking, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
