gauges.what kind? help
Old 07-29-2010, 11:31 AM
GR$$N$'s Avatar
GR$$N$
GR$$N$ is offline
looking into getting some gauges but was curious as to what type all of you are running.im getting either a 3 or 4 pod just havnt decided what to put in yet.obviously boost would be one and trans temp another.but what other type do you guys run or "recommend" to run.its my daily driver but also i use it to tow.thanks
Old 07-29-2010, 11:52 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
I run and prefer Isspro gauges. I had the EV series in my SD and now have another set of EV's in my OBS. The EV's work just fine and look great, but the EV2 and Performax series are really slick and install easier if you can swing the extra cost.
Old 07-29-2010, 12:00 PM
GR$$N$'s Avatar
GR$$N$
GR$$N$ is offline
ya havnt decided which ones i was going to go with yet.possibly was going to go with autometer.what gauges are you running? 3 or 4?
Old 07-29-2010, 01:12 PM
overthehillbill's Avatar
overthehillbill
overthehillbill is offline
If you decide to go with four, pillar mount, you might want to check your visor for clearance. Just my .02
Old 07-29-2010, 01:23 PM
GR$$N$'s Avatar
GR$$N$
GR$$N$ is offline
ill be going with the one that goes on the windshield above the mirror.but thank you.thats a good point with the one im going with as well so ill probably just do the 3 pod
Old 07-29-2010, 01:24 PM
onelionhunter's Avatar
onelionhunter
onelionhunter is offline
EGT
EGT is the other important gauge, see what your exaust temps are doing, weather you are about to melt anything. the 4th is personal preference, fuel pressure, voltage are two that come to mind.
Old 07-29-2010, 01:47 PM
AmericanMade's Avatar
AmericanMade
AmericanMade is offline
Youre going to want a pyro gauge as well. the big three that most people run around here are Boost, Trans temp, and pyro.
Clay over at Riffraff has a nice kit. it's not the over the rearview mirror, it's a pillar kit. but comes with everything you need. and isn't a lot more than getting everything separetally, but comes with things like a tap set for the pyro probe, and pre painted, and etc. and the gauges are some of the best recomended Issspro EV2.
Old 07-29-2010, 02:10 PM
GR$$N$'s Avatar
GR$$N$
GR$$N$ is offline
thanks guys i appreciate it.and im staying away from the pylar setup.my boss has the 3 gauge pillar in his truck and its too much of a blind spot for me and considering all the blind spots i already have from my truck being so tall i dont want to make another blind spot.but thanks again i will be ordering the 3 gauge above the mirror as well as my dp tuner today
Old 07-29-2010, 04:16 PM
kccatpower's Avatar
kccatpower
kccatpower is offline
i think you have it covered, one thing to considered is if you go with a 4 pod you can get the dp in a round style to fill that extra hole.
Old 07-29-2010, 05:43 PM
superduty4x4
The "standard 3" gauges are boost, trans temp (if you have an auto), and a pyro. For a 4th gauge fuel psi is a good one, or get an Aeroforce Scangauge from Terminator Engineering so you can read/pull codes and monitor any sensor on the truck. Plus it also has 2 aux. inputs for stuff that doesn't have a sensor... like fuel psi
Old 08-02-2010, 03:52 PM
GR$$N$'s Avatar
GR$$N$
GR$$N$ is offline
dang i wish i would have read that alot sooner.i didnt know the tuner came in a round setup like that otherwise i would have gotten the four pod and done that.but its already being sent to me.next truck i guess
Old 08-02-2010, 04:02 PM
spdmpo's Avatar
spdmpo
spdmpo is offline
I can't really recommend anything because I've only used 1 thing, and that's the BD X-monitor. I like it, it works, and it's low profile - which was the main reason I went that route. I just didn't want a 3 or 4 pillar pod. If I could do it over again I'd go with an F650 dash and put the 2" Autometer gauges in there, but that dash wasn't really talked about much when I did it so I didn't really know about it.
I think a lot of people like the Isspro, and I'm sure they are very nice but they are $ compared to Autometer mechanical gauges, which I've used in other car projects I've had.
Old 08-02-2010, 04:07 PM
Spool&Go's Avatar
Spool&Go
Spool&Go is offline
Can anyone give me links and pricing for the EV's and EV2's, along with the pillar guage mount. I will most likely have someone install it for me unless it is easier than I think and get a hold of a write up. I usually don't like messing with electrical stuff unless it's stereo. Thanks!
Old 08-02-2010, 04:18 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Gauges are easy-peasy to install. Here's a writeup. Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Talk with Clay about pricing.
Old 08-02-2010, 04:25 PM
Spool&Go's Avatar
Spool&Go
Spool&Go is offline
Sweet Thanks. Reps! And are you sure these directions will work for my E99? The very first step says "for the 2003 and later......"
Quick Reply: gauges.what kind? help
