New User with a What is this?
I've had my truck for a few months and I've learned and learned from this forum, and gained confidence to do a few little jobs so far. This forum is great. I've got a 2001 CC 4x4, with 220k miles.
Today I was working on the fuel bowl with Guzzle's o-ring replacement kit due to a leaky drain valve. I've got something wrong with a loose sensor that I don't know what it is.
It's located just underneath the fuel bowl, on the driver's side, there is a sensor attached to a horizontal rod (is this on the HPOP?). The wires for this sensor join the fuel heater/water sensor cable within 2 inches. The horizontal rod is threaded on the end, but I don't have a nut on the threads to hold the sensor in place.
Anybody know what that thing is?
on
Check out this thread .. post #5 and post #9
https://www.ford-trucks.com/forums/9...-starting.html
Thanks guys. After looking at those pictures you're right. It's the IPR.
Mine is hanging on the rod from the HPOP without anything to keep it from sliding off towards the firewall. The sensor wiring seems to hold it in place.
https://www.ford-trucks.com/forums/7...l-is-that.html
Post #11 really showed it to me. I'm missing the spacer and that cheap end cap.
I haven't noticed anything odd about the engine. Is there an issue with how mine is right now?
Sure, just go back to Guzzle. Replacement O-rings for Ford Diesel Engines
But also grab a flash light and look around in the valley of your motor. There's a good chance the parts are laying there on top of the motor just covered in gunk so they're hard to see.
on
Here is a good resource for Powerstroke system info. Diesel Technician Society It will take some of that mystery out of how things work.
I did put a tie wrap to hold the IPR in place. I didn't notice any difference with the engine. The IPR has been staying on the rod by itself for as long as I've had the truck.
I guess that there is a coil in the IPR that pulls the relay within the HPOP, and when this coil is activiated my IPR was moving itself into place. The tiewrap should work fine until I place my next order with Bob.
brian42
24
05-28-2015 07:29 PM
JOHN2001
19
01-28-2013 11:29 AM
77f100
03-27-2001 11:16 AM
