Wont start just clicks and gauges go crazy - Ford Truck Enthusiasts Forums
Old 07-27-2010, 09:45 AM
jvjaj jvjaj is offline
jvjaj is starting off with a positive reputation.
F150 5.4L XLT battery good, was running and starting fine. When try to start get a clicking noise in fuse box under dash. Fuse number(relay) 2.
Old 07-27-2010, 07:06 PM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
If your battery is tested good and you haven't already, remove and clean your battery cable clamps and the battery posts.
Old 07-27-2010, 07:56 PM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
mine did the same and it was the battery.
Old 07-28-2010, 08:30 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Another vote for a bad battery.
Old 07-29-2010, 02:20 PM
basecamp basecamp is offline
basecamp is starting off with a positive reputation.
It is acting like a bad battery. Either your battery is bad or your cables getting power to the vehicle are dirty. That is how they act when they don't have enough power to start.
Old 07-29-2010, 05:19 PM
XGraysonX XGraysonX is offline
XGraysonX is starting off with a positive reputation.
agreed on the battery.... if the battery is fine id say test the starter on the tranny not the firewall...
EDIT: that is if its not turning over but the celanoid is still putting through a charge to ur gauges*
Old 07-30-2010, 09:38 PM
ls973800 ls973800 is offline
ls973800 is gaining momentum as a positive member of FTE.
One more vote for the battery! When mine went, the truck never gave any indication of being bad. I had made several stops that day, and got into the truck and tried starting it.
Just heard clicks from the fuse area. Really didn't think it was the battery, because I had driven about 20 miles between each stop.
Yes, it was the battery!
Old 08-03-2010, 06:55 AM
BlitZ_ BlitZ_ is offline
BlitZ_ is starting off with a positive reputation.
when my truck did this it was the solenoid on the firewall.. I always start with the cheapest thing first. Cross the terminals with a screw driver with the key in the run position and see if it starts up then. If so then thats your problem its a 10 minute fix make sure you disconnect the battery
1998 f-250 starting issue cordonja 1997 - 2003 F150 14 12-24-2014 11:47 AM
Clicking noise from fuse box TheProfessorofTOOL 1997 - 2003 F150 1 12-26-2013 04:01 PM
PCM fuse is clicking Gonu50 1997 - 2003 F150 5 03-09-2013 10:07 AM
Clicking sound under the hood when engine turns off on 08 Expedition Packing4Protection 2007 - 2014 Expedition & Navigator 0 12-27-2010 06:22 PM
Power Window Clicking Sound Aztrainer 1997 - 2003 F150 12 01-29-2008 08:29 PM
Tags
2003, click, clicking, clicks, crazy, escape, f150, ford, fuse, gauges, speedometer, start, starting, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
