Where is this oil leaking from? Cylinder head?
Ok gents, when replacing the upper and lower intake manifold gaskets I found a fair amount of what I am assuming is blow-by oil residue in the manifold. Truck has 210,000 miles so I assume this is to be expected.
Also noticed oil in a strange place, at the rear of the heads where they meet the block. What does this look like to you guys? I have no idea, can the head leak oil or have blow-by?
Also what can you do for the blow-by in the intake manifold other than replace the piston rings/rebuild? I was going to let if fly as-is because it still runs well.
chuffer
13
07-24-2017 08:44 PM
tastyklair
07-05-2005 12:48 PM
