You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am planning to TIG weld the 8 into 1 exsaust manifold, and run a high power oil pump with a oiling cooler and line to the turbo.
Welding and fabrication isent a problem. Finding the proper turbo and injection system is.
I want to do a bi-turbo set up. Much like the ford 6.4 (I believe, could be the 6.0 I can't recall). So I will have a small turbo spoiling up fast and a larger turbo for higher rpm.
For a fuel system I want to run a carborator, fuel injection is very costly and this is a budget build.
As for the frame, the rear end has a 9in and trailing arms, I plan on keeping the axle and doing eather a triangulated 3 link, or a 4 link suspention. For tranny I have a C6 automatic
Anyone know where i can get quarter pannels? I can't seem to find any
D2OZ9727846A .. Right Quarter Panel / Obsolete
D2OZ9727847A .. Left Quarter Panel / Obsolete
Fits: 1972/76 Ranchero / No Ford Dealer or obsolete parts vendor has any.
Where is the damage (prolly caused by rust), above the wheel wells and along the bottom of the quarter panels?
Find a 1972/76 Torino 2 door, then cut the quarter panels from it, then splice in the lower section of the 2 door panels to the Ranchero's quarter panels.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Thanks man. I am considering cutting a inch or 2 out of the rear quarter pannels to eliminate rust and fit larger tires. Rust in rocker pannels shouldn't be to difficult to replace or patch.
