4 wheel drive not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-27-2010, 01:40 AM
rednexinc15 rednexinc15 is offline
rednexinc15 is starting off with a positive reputation.
i got a 2006 f250 with the powerstroke in it and i got no 4 wheel drive on the dash the light comes on but it dont engage even if i got out and lock the hubs it still dont work and help would be great thanks
Old 07-27-2010, 12:03 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
If the light is on, that means the transfer case actually shifted into 4x4.
With the switch in 4x4, and the light ON, jack up the front wheels off the ground and spin each one. See if the u-joint behind the wheel spins with the wheel. It sounds like one of your hubs is hanging up and not really locking.
Old 07-27-2010, 12:12 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
It may be worth taking the shift motor off of the transfer case and inspecting it also.
I believe it is possible for the motor to break in such a way that it still moves the switches but doesn't actually turn the shift cam shaft. The switches are what reports back to the 4WD control modules that the shift has completed.
Old 07-27-2010, 01:31 PM
Krewat's Avatar
Good point David, if the square drive rounded off, or something else broke, maybe...
Old 07-27-2010, 01:34 PM
I seem to recall someone reporting that just that happened. The square drive rounded off of the shaft, or the motor, I don't remember which. It's probably not very common, but worth checking.
Old 07-28-2010, 04:23 AM
Thanks guy how to them lock in it is a vacum that does it right
Old 07-28-2010, 06:25 AM
5.4f250sd's Avatar
5.4f250sd 5.4f250sd is offline
5.4f250sd is starting off with a positive reputation.
yes vacuum is what automatically locks the hubs.
Old 07-28-2010, 12:48 PM
where is the shift motor om the tranfer case
2000 ford f-150 4 wheel drive proplem kevin remillard 1997 - 2003 F150 4 04-15-2014 07:11 PM
4 wheel drive not working rougerocco Excursion - King of SUVs 1 12-26-2012 09:26 PM
Electronic 4 wheel drive coop3526 1999 to 2016 Super Duty 0 12-27-2010 12:09 AM
Hard to move 4x4 manual shift big J.V. 1987 - 1996 F150 & Larger F-Series Trucks 14 03-02-2008 05:26 AM
How many got a 2 wheel drive? russ&irene 2004 - 2008 F150 16 08-02-2006 10:38 PM
Tags
06, 2006, 4wheel, 60, 94, drive, engaging, f250, f350, ford, lights, powerstroke, stop, wheel, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
