What kind of sealant do you all use on a water pump? I've been using permatex #2, but I've also had several leaks. I'm usually concerned about breaking bolts off or stripping them, so it may just be a matter of me not getting the bolts tight enough. Is permatex #2 good for this, or should I be using something else?
__________________
92 F150, 4x4, M/T, 3 body lift, 2 front lift coils, 33 tires, Warn hubs, Traction-Lok LSD, Superwinch EP9.0
302, Trick Flow Twisted Wedge 170 heads, 9.2:1 static compression ratio, Lunati 61001 (256/262) cam, 1999 Explorer intake & throttle body, 24 lb/hr Accel injectors, Hedman shorty headers, mass air conversion, Granatelli 75 mm mass air flow sensor, K&N conical filter, A9L ECM, tuned with Moates Quarterhorse & Binary Editor
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
