Converting from Automatic to Manual, some pics and explanation...
  #31
Old 08-15-2012, 03:28 PM
zrroper's Avatar
zrroper
zrroper is offline
And also I don't want to sound stupid but what's the yoke for?
  #32
Old 08-15-2012, 04:12 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I went ahead and changed the yoke to match the driveshaft rather buy a conversion u-joint.
Plus, I broke the 1330 yoke unloading it so I needed another anyways
Josh
  #33
Old 10-29-2012, 02:28 PM
grasfarmr73's Avatar
grasfarmr73
grasfarmr73 is offline
Ok guys, I hope you can help me.
I am in the middle of a similar swap. I had a 360 and a C6 in a 73' F100 2wd. I have an 86 300 and a 70's New Process sitting in it now.
I got the different 300 drivers side engine pedestal so I could bolt it right in. I understand that many people say that the passenger's side engine pedestal for the 300 and the FE is the same so I kept that one.
I did not change the location of the transmission cross member or turn it around.
I bolted the transmission first and over the weekend I set the engine in. The passenger side pedestal is about 0.5" too far forward for the engine mount. The drivers side mount seems to fit pretty well but the pedestal mount is taller and it may be possible that it is bending to accommodate the engine being farther back.
In the transmission's current location, the shifter comes through the floor right in the middle of the hole in the floor (the middle of the hole in the floor plate for manual transmissions)
So, does anybody know if the passenger side 300 pedestal is different from the FE pedestal?
Or do I need to move the transmission 1/2 an inch some how? Will turning the cross brace 180 degrees do this?
  #34
Old 10-29-2012, 02:56 PM
Bullitt390's Avatar
Bullitt390
Reuse the old FE engine perch.
Sounds like you're trying to use a pre-78 mount along with a 78+ mount.
Josh
  #35
Old 10-29-2012, 03:53 PM
grasfarmr73
I forgot to add that I got the older style mounts for the engine as well. I measured the forward distance from the studs on each style of the right side engine mount to the forward bolt hole and they are practically the same, that is, the distance from the stud to the hole is the same. The angles of the pads in relation to the ground are different though.
  #36
Old 10-29-2012, 04:32 PM
Bullitt390's Avatar
Bullitt390
Not sure as the perches are the same 73-76 for FE and 300
Josh
  #37
Old 01-30-2019, 05:01 PM
Robby197481's Avatar
Robby197481
Robby197481 is offline
converting my 74 a C6 to T19
I'm doing the same swap in my 1974 f350 with the 390 engine. Can anyone tell me or send me a picture of how the pivot point attached to the engine block I can't figure it out.
  #38
Old 01-31-2019, 12:12 AM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
This link from LMC might be of some help (F100-250, but probably the same)...........Truck Parts and Truck Accessories
  #39
Old 07-11-2019, 04:29 PM
Big Block Enthusiast's Avatar
Big Block Enthusiast is offline
Trailering
Neutral Safety Switch
Hey I know I super late to this thread but I look at these old forums all the time. Im 18 I own a few old Fords and I'm working on a 78 F-150 Ranger XLT. Its got a 460 with power steering and A/C. When I bought it, it had a c6 but I've never been a fan of 3 speed autos so after overhauling the engine and upgrading a few things I scavenged some parts and found a T18 from a 79 F250 with a 460 for $20, no play in the shaft all. I did every thing you did exept I decided to converted into a hydrolic clutch instead of using the z bar. Everything works mechanicaly but I ran into a problem and I haven't read anywhere about it. Since this truck has everything avaliable in that year (A/C, Power Steering, Cruise Control, ext.) it has an unbelievable amount of wires under the dash and in the engine bay and I can't get through what to do about the Neutral Safety Switch (meant to prevent engine crank while trans was in gear) and what to do so the back up lights work with the new T18. What I mean is I'm clueless as to what to do so I can bypass the switch so the wire going to the solenoid is always hot and what wire I have to move around to make it work with the switch in the transmission. I'm very new to the game since 16 when I bought my first 460 dentside and I dont want to spend money on things i dont need to when i can just modify it myself. Any suggestions amd tips are well appreciated.
Thanks.
  #40
Old 06-30-2021, 12:59 AM
Trailering
Wink
Originally Posted by Big Block Enthusiast
Hey I know I super late to this thread but I look at these old forums all the time. I'm 18 I own a few old Fords and I'm working on a 78 F-150 Ranger XLT. It's got a 460 with power steering and A/C. When I bought it, it had a c6 but I've never been a fan of 3-speed autos so after overhauling the engine and upgrading a few things I scavenged some parts and found a T18 from a 79 F250 with a 460 for $20, no play in the shaft all. I did everything you did except I decided to convert it into a hydraulic clutch instead of using the z bar. Everything works mechanically but I ran into a problem and I haven't read anywhere about it. Since this truck has everything available in that year (A/C, Power Steering, Cruise Control, ext.) it has an unbelievable amount of wires under the dash and in the engine bay and I can't get through what to do about the Neutral Safety Switch (meant to prevent engine crank while trans was in gear) and what to do so the backup lights work with the new T18. What I mean is I'm clueless as to what to do so I can bypass the switch so the wire going to the solenoid is always hot and what wire I have to move around to make it work with the switch in the transmission. I'm very new to the game since 16 when I bought my first 460 dentside and I don't want to spend money on things I don't need to when I can just modify it myself. Any suggestions and tips are well appreciated.
Thanks.
Yea so I ended up cutting the wires on the neutral safety switch that same day. There were 4 wires: 2 for the starter and 2 for the backup lights. I just connected the two for the starter so that the engine could start and then the other two I connected to a connector which I connected to the reverse switch. Easy as ****. But thanks for the help, you guys.
Now I am almost 20 and I am doing the same thing for my 94 Bronco so I am back here as always looking for ideas because it has an E4OD, not a C6, and that bitch has way more than 4 wires. Shouldn't be that hard. This thread is dead anyway lmao.
Rossta86
Engine Swaps
51
10-17-2022 08:52 PM
Nally427
21
11-02-2020 04:43 PM
bad_habit_F350
16
06-02-2020 10:54 PM
Davgt500
6.7L Power Stroke Diesel
31
11-18-2016 09:00 AM
ReBilld
51
07-14-2012 06:39 PM
Quick Reply: Converting from Automatic to Manual, some pics and explanation...
