HELP! FUEL LEAK! '05 F250 DIESEL - Ford Truck Enthusiasts Forums
Old 07-26-2010, 10:26 PM
dampink dampink is offline
dampink is starting off with a positive reputation.
I'VE GOT A LEAK THAT APPEARS TO BE COMING FROM THE SECONDARY FUEL FILTER HOUSING (THE ONE IN THE ENGINE COMPARTMENT)...IT'S NOT COMING FROM THE FILTER, BUT FROM THE SIDE, WHERE THERE ARE 4 ALLEN BOLTS THAT ATTACH A FITTING TO THE SIDE OF THE HOUSING...CAN I CHANGE OUT THE GASKET FOR THAT PIECE? I'VE ALREADY TIGHTENED THE BOLTS, BUT THE LEAK PERSISTS. THANKS!
Old 07-26-2010, 10:40 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Can you take some pictures???
Do you see exactly where it is leaking? That is the regulator housing. Clean it off then turn the key. Once the key is on the pump will start and presure will build. You should then see the leak.
Start a signiture so we know what you drive
Old 07-26-2010, 10:57 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Now is the time to do your fuel pressure regulator update. Go to your local nearest Ford dealer and ask for part number 3C3Z-9T517-AG. The kit includes everything needed to repair your leak AND bump up fuel pressure from 55 psi at idle to 65 psi. Kill two birds with one stone.
Old 07-26-2010, 10:58 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Hopefully you didn't over tighten the bolts and crack the housing. The gasket is pretty much reusable, but is readily available. As Steve said.....check it with the pump only running--it should be very easy to see.
Old 07-26-2010, 11:07 PM
SmokerSteve
Thanks for the reply...I'll be sure to setup so that everyone knows what I'm drivin...I've got a 2005 f250 SuperDuty 6.0. Here's a link to a photo...
Picasa Web Albums - DAC - Untitled Album
the leak is NOT from the brass plug, or from the fuel lines that enter/exit this housing...the leak appears to be coming from the seal - the side piece that is attached to the main housing with the 4 allen bolts visible in the picture.
Thanks again for the help.
m.a.
Old 07-26-2010, 11:12 PM
Quote:
no, I'm pretty careful with these things..I didn't overtighten them. The leak was there prior to my changing the filter...I thought that changing the filter would stop the leak..but alas, no.
NOTE: THE REASON I CHANGED THE FILTERS IN THE FIRST PLACE IS DUE TO A HOT START PROBLEM; I HAD A DIESEL MECHANIC TELL ME THAT CHANGING THE FILTERS WAS THE FIRST PLACE TO START...THAT'S FINE, BUT I STILL HAVE THE HOT START ISSUE. IS IT DUE TO THE REGULATOR ISSUE? PLEASE ADVISE.
THANKS!
Old 07-26-2010, 11:18 PM
HOT START PROBLEM
TO CLARIFY: When I start my 6.0 superduty diesel cold, it's fine...starts right up. If I drive all over town and turn it off, I have to wait as long as 20 minutes (or more) for it to cool down before it'll start again. Usually that requires me putting the pedal to the floor, whereupon I get a super-revved start, if that makes sense (when it finally starts, there is an initial RPM surge, then it runs normal)...again, it's only when it's hot. When it's cool, it starts on the spot.
Old 07-26-2010, 11:26 PM
m-chan68's Avatar
Quote:
Well the diesel mechanic isn't very familiar with the operation on these engines then. THIS issue is likely caused by a high pressure oil system leak. These engines use high pressure engine oil to control fuel pressure at the combustion chambers. When the engine is cold, the oil thickens up enough to overcome the leak source to enable the engine to start. But when the engine is at operating temperature, the oil thins out and can't produce enough pressure for the engine to start. Your STC fitting is likely needing to be ditched in favour of the updated one piece branch tube connector. The part number from Ford for this kit is 4C3Z-9B246-F.
Old 07-26-2010, 11:43 PM
THANK YOU!
I'm going to look into getting these parts...I am really grateful for your help, guys. This forum is seriously cool...Thanks again!
Old 07-26-2010, 11:47 PM
Quote:
I will look this up...but could you tell me what the STC fitting is? Hope this is not too elementary..I'm not a mechanic (really.)
Old 07-26-2010, 11:52 PM
m-chan68's Avatar
Here is a good article to describe the part:
Diesel Technician Society
Old 07-27-2010, 07:24 AM
Is there any publication or internet link that anyone knows of that will show me how to replace the HPOP connector bracket (replacing the STC) in my '05 f250 SD?
Old 07-27-2010, 07:36 AM
Do you know that the STC fitting is under the turbo under a cover at the back of the motor? If you aren't a mechanic then you would probably be better off to have it done, but it's fairly costly since it's labor intensive.
Old 07-27-2010, 09:21 AM
no, i didn't know this...though i'm not a mechanic, i've replaced clutches, trannys, ball joints, drive train segments etc over the years...and i'm very meticulous...unless this is just not possible without the full spectrum of shop tools, i'd like to give it a shot...is there any other simpler, just as likely fix to this issue (is the STC a misdiagnosis?). Please advise. Thank you all so much!
Old 07-27-2010, 09:30 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
05's are notorious for the stc fitting leak.
Fuel Filter Housing POS Ė Iím stumped mark460 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 09-02-2016 08:34 AM
No Diesel in filter housing F350XLT 1994.5 - 1997 7.3L Power Stroke Diesel 1 09-28-2015 05:29 PM
fuel leak frizzen 6.0L Power Stroke Diesel 5 09-06-2015 05:59 PM
Fuel leak at electrical sensor in fuel filter housing Stephenn95 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-19-2015 02:01 PM
Banjo bolt on fuel filter housing? KDAVID1 6.0L Power Stroke Diesel 4 03-08-2015 10:23 PM
Tags
2002, 2005, 60, diesel, f250, f350, floormat, ford, fuel, high, leak, leaking, litre, oil, pressure, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
