2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Heated / Cooled seats
Old 07-26-2010, 06:02 PM
Jay's Avatar
Jay
Jay is offline
Anybody know of a decent ungrade for the seat coolers on an 07 Expy. Mine don't work too well (never have).
Old 07-26-2010, 06:53 PM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
I don't know what the issue is with yours, mine work great. . .. just perfect to keep the backside from getting sweaty.
You could easily upgrade though, pull the fan out and look up the specs for it. Then just find a similar model (I assume 12V) that is larger/high cfm. There are many computer fans that are 12V, I used to use them for audio equipment all the time.
Old 07-26-2010, 06:57 PM
glruff's Avatar
glruff
glruff is offline
I think there is a TSB out there for the seat cooling issue. Something about reprograming so the fan runs at a higher speed to cool the seats.
Try here for info,,, https://www.ford-trucks.com/forums/9...led-seats.html
Old 07-26-2010, 09:00 PM
Jay's Avatar
Jay
Jay is offline
I had the TSB preformed to speed up the fans just after it was new. Everything is running, it just doesn't do a very good job of cooling.
Old 07-26-2010, 09:23 PM
glruff's Avatar
glruff
glruff is offline
My new 2010 works about the same as yours. It starts off great then after about 40 minutes it seems to do little or no cooling.
I have to take mine back soon for the first service and will ask them to check this and report back.
Old 07-28-2010, 04:34 PM
CarbonClear's Avatar
CarbonClear
CarbonClear is offline
The ford fans don't work well period. I have had mine adjusted to run at the higher speeds, but as some others have posted after 20 or minutes its doesn't do much. Part of the problem its a fan pulling from below the seat and will pull air at whatever the temperature is at under seat. Other manufacturers have it done right where the cooled/ventilated seat is actually part of the a/c. I guess I should have spent the extra 20k to get them
Carlene
Appearance & Dress-Up
12-26-2002 04:26 PM
screwy
1978 - 1996 Big Bronco
11-25-2002 08:47 PM
06-15-2001 11:33 AM
Black98F150STX
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
06-14-2001 11:38 AM
Quick Reply: Heated / Cooled seats
