Stuck in 4x4 low please help! - Ford Truck Enthusiasts Forums
Old 07-26-2010, 06:13 PM
joshlee joshlee is offline
joshlee is starting off with a positive reputation.
Ok i am a member of fordtruckworld.com and could not get any help from there, so i thought maybe someone here could help.
My main problem right now is that i am stuck in 4x4 low. Orgnially(should have left it at this) my truck would not do anything, no 4x4 high or low lights when i turned the switch.(lights worked when truck is first turned on) I reseached it on the net and came across the idea to tap the Transfer Case Motor. I did this and my truck locked in 4x4 low and would not come out. I kept tapping on it while someone turned the dash switch and nothing, so i ordered a new(rebuilt) motor (160.00!!) I got the new motor today and while installing it(i replaced the 2 speed wires) i turned the switch and it went in 4x4 high but i put it back in 4x4 low in order to bolt the motor to the transfer case.
After i bolted it on i tried to take it out of 4 low(in netural and foot on brake) and it would not disenage. My front hubs will not lock, i am going to get on this after i get it out of 4x4 low(take it to a friends shop so i can lift front end up ect.)I have recently replaced the iwe soilnoid on the passenager side firewall.
Any ideas for be greatly appreciated. Sorry about spelling i am kind of in a fix here, i need a truck to drive! I have checked all fuses.
Old 07-26-2010, 06:42 PM
screwy's Avatar
screwy screwy is online now
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Drive it a few feet and try again, sometimes it can bind a little bit.
Old 07-26-2010, 06:52 PM
bridge's Avatar
bridge bridge is online now
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Second the above. Also, trying putting it in neutral, then switch to 4x4 high and put it into gear. If it goes into high you should be able to get it into 4x2 while in gear. 4x4 low is sometimes fickle when it comes to switching back and forth. Good Luck.
Old 07-26-2010, 06:53 PM
I hated to do it but I even drove it .5 mile. I have even pushed it forward and backward and still nothing.
Old 07-26-2010, 09:50 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
How many miles are on the truck and when was the last time you did anything to the transfer case?
Old 07-26-2010, 09:56 PM
miles is 117,000k no work done to transfer case (4x4 has not been used very much).
Old 07-26-2010, 10:37 PM
bridge's Avatar
Quote:
Originally Posted by joshlee View Post
....(4x4 has not been used very much).
That's were the problem starts with theses trucks. Use it or loose it. I engage mine a couple times a month to keep the solenoids, actuators and flux capacitors moving.
That being said, this is the first time I've heard of one stuck in 4x4L. So, you tried putting it into drive, going a few feet, putting it in neutral, putting it in 4x4H and going a few more feet?
Old 07-26-2010, 10:44 PM
I am basically tried everything to get it out of 4x4 low. Pushing it six or seven feet both ways (read on the internet would sometimes work). I am shifting it correctly in netural foot on brake and even incorrectly. I have drove it forward and backward while shifting in and out of 4 low and leaving it in the 4 high position. I am not sure where my problem is i am wondering if it is the switch in the dash?
Old 07-26-2010, 11:34 PM
screwy's Avatar
I would start looking at the motor again, double check wires, mounting etc.
Old 07-26-2010, 11:40 PM
i was going to re install the motor in the morning. Correct me if i am wrong when i remove the motor from the transfer case, i should be able to take the dash switch and move it from 4x4 low to 4x4 high and see the transfer case motor move? ( the small triangular indention on the side of the transfer case motor which bolts to the transfer case.)
thanks
also could i use a test light on the wiring harness of the transfer case motor to test my dash switch?
Old 10-21-2016, 02:03 PM
seethesepitts05 seethesepitts05 is offline
seethesepitts05 is starting off with a positive reputation.
Stuck in 4x4 low
thanks
Did you get this figured out? even the Ford diesel specialty shop I took it to couldn't figure it out
Old 10-21-2016, 03:41 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Ooooops ..... my bad!
Old 10-22-2016, 09:32 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
seethesepitts ------------ why don't you start a new thread and tell everyone what your problem is and what has been done or seen... YES, you can remove the transfercase motor , operate the dash switch, and see the motor rotate... but I don't think that will fix your problem, unless you changing out the motor.
2003 Expedition possible bad 4x4 control module? underdogl3 Expedition & Navigator 5 02-18-2016 08:00 PM
1999 Ford Explorer 4x4 issue with reverse Tim Curbow Explorer, Sport Trac, Mountaineer & Aviator 2 03-15-2015 06:07 PM
4X4 stuck on caddy 6.4L Power Stroke Diesel 1 04-05-2014 02:23 PM
4X4 LOW stopped working shore 1999 to 2016 Super Duty 10 04-27-2013 05:34 PM
06 F350 Superduty - 4x4 problems need help!!! bigboytoys08 1999 to 2016 Super Duty 8 03-03-2010 11:56 PM
Tags
2001, 2008, 4l, 4x4, brake, expedition, f150, ford, gear, high, low, problem, stuck, switch, switching
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
