Coil ground on a 460 in 87 E350 winnie
Anybody know where the actual ground connection is for the coil?
I get 12 volts on the positive side when I check to good ground. But on both wire terminals it fluctuates from 3 volts down to .1.
Can I reground the coil somewhere else?
Thank you in advance,
Jeff
FWIW it is a 460 in a E-350 chassis for a Winnebago motor-home.
I have replaced all ignition wires, coil cap rotor. Each one seemed to fix the problem for a while. It has run fine every once in a while but then won't start.
Jeff
I see the OP says he has 12 volts on the +side of the coil.
Did you mesure that, or use a test-light?
Should'nt it be more like 6.5 volts? Doesn’t the Ballast resistor drops the voltage ?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Thanks<o></o>
Bruce<o></o>
<o> </o>
<o></o>
Thanks<o></o>
Bruce<o></o>
<o> </o>
It was 3 volts fading to .1 using the positive and negative connections.
I measured 12 volts between the positive and a good ground.
I checked the voltage on the + side of the coil to ground and it is 6.5 volts.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I thought that the electronic ignition used 12 volts to the coil, so we check another vehicle with the motorcraft ignition and it was 6 volts.<o></o>
<o></o>
This was on a 1987 460, carbureted, MoHo. <o></o>
<o></o>
Thanks.
Rebuilt the Carb today, of course it started right up and idled for 7-8 minutes then died. Wouldn't restart, but at least it won't catch on fire now.
Took out the coil and it checked out fine.
Just looked at the Duralast/Control Module - Ignition online and for 27 bux should have just bought one.
I am guessing that is the next step in the electoral system.
The coil is grounded in TWO places. The low voltage (12 volt) side grounds thru the sensor and the high voltage side grounds thru the spark plug. But if you are checking voltage with the sensor on the negative side of the coil you will get all sorts of strange readings. But your symptom of starting and running until warm and then dying is a classic bad coil problem.
A Marlin 1895SS,
Ruger #1,
H&R Buffalo Classic with vintage scope,
H&R Model 1873 "Trapdoor" replica,
My original Model 1873 "Trapdoor" made in 1889,
And of course my Thompson Contender Super 14 shown here with the 1895 and the #1.
Brother Les
08-28-2014 03:23 PM
lvs2fly
23
10-03-2012 09:36 PM
samahi72
05-04-2008 01:16 PM
