Coil ground on a 460 in 87 E350 winnie - Ford Truck Enthusiasts Forums
Old 07-26-2010, 04:44 PM
Civilian Civilian is offline
Civilian is starting off with a positive reputation.
Anybody know where the actual ground connection is for the coil?
I get 12 volts on the positive side when I check to good ground. But on both wire terminals it fluctuates from 3 volts down to .1.
Can I reground the coil somewhere else?
Thank you in advance,
Jeff
FWIW it is a 460 in a E-350 chassis for a Winnebago motor-home.
I have replaced all ignition wires, coil cap rotor. Each one seemed to fix the problem for a while. It has run fine every once in a while but then won't start.
Old 07-26-2010, 08:06 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
The ground side is the trigger for the coil to fire. It grounds through the ignition box.
make sure the coil BRACKET is got a clean connection to the engine and check the ignition box grounds (actually ALL the grounds are suspect)
Old 07-27-2010, 09:41 PM
fordmanjoe1987 fordmanjoe1987 is offline
fordmanjoe1987 is starting off with a positive reputation.
sounds like possibly a bad coil if grounds check out good. should have like .7 on primary and like 9-12k on secondarys.
Old 07-28-2010, 02:04 PM
Bruce David Bruce David is offline
Bruce David is starting off with a positive reputation.
I see the OP says he has 12 volts on the +side of the coil.
Did you mesure that, or use a test-light?
Should'nt it be more like 6.5 volts? Doesn’t the Ballast resistor drops the voltage ?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Thanks<o></o>
Bruce<o></o>
<o> </o>
Old 07-28-2010, 02:49 PM
Yes with a multimeter.
It was 3 volts fading to .1 using the positive and negative connections.
I measured 12 volts between the positive and a good ground.
Is that in the coil or at the other end of the wire?
Old 07-29-2010, 05:39 PM
I checked the voltage on the + side of the coil to ground and it is 6.5 volts.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I thought that the electronic ignition used 12 volts to the coil, so we check another vehicle with the motorcraft ignition and it was 6 volts.<o></o>
<o></o>
This was on a 1987 460, carbureted, MoHo. <o></o>
Old 07-29-2010, 07:07 PM
Thanks.
Rebuilt the Carb today, of course it started right up and idled for 7-8 minutes then died. Wouldn't restart, but at least it won't catch on fire now.
Took out the coil and it checked out fine.
Just looked at the Duralast/Control Module - Ignition online and for 27 bux should have just bought one.
I am guessing that is the next step in the electoral system.
Old 07-30-2010, 10:08 AM
Where did you get the spark box for 27 bucks?
I'll carry a spare for that price.
The coil cost me 37.
Old 07-30-2010, 10:55 AM
I am going to pick it up this morning from Autozone.
though My Father-in-law (previous owner) thinks it has something to do with the smog system, as it seems to die when it is warmed up.
Old 07-30-2010, 11:55 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
The coil is grounded in TWO places. The low voltage (12 volt) side grounds thru the sensor and the high voltage side grounds thru the spark plug. But if you are checking voltage with the sensor on the negative side of the coil you will get all sorts of strange readings. But your symptom of starting and running until warm and then dying is a classic bad coil problem.
Old 07-30-2010, 06:12 PM
Success!!!!
Put a new control module in and 20 starts later it is 100%
The replacement took less than 5 minutes.
I'm going to the beach now.
Thanks for the advice.
Bear- What do you have in 45/70? I have been looking at the Marlin 1895 Cowboy
Old 07-30-2010, 06:58 PM
Bear 45/70's Avatar
Quote:
Originally Posted by Civilian View Post
Success!!!!
Asking me about 45/70 is a no-no. It is my favorite caliber and I have;
A Marlin 1895SS,
Ruger #1,
H&R Buffalo Classic with vintage scope,
H&R Model 1873 "Trapdoor" replica,
My original Model 1873 "Trapdoor" made in 1889,
And of course my Thompson Contender Super 14 shown here with the 1895 and the #1.
Old 07-31-2010, 12:05 PM
Thanks for the info.
The local autozone has one in stock waiting for me.
After 23 years, I think its time to change it before it dies
in the middle of no where.
What beach are you going to?
I spend time a Docweiler every year.(its close to home)
Happy trails.
Bruce
Wiring wmkmun 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-17-2016 08:39 AM
88 E-350, 460 Quit running while driving Dr D 1968-2013 Full Size Vans 6 07-13-2015 07:27 PM
Installing aftermarket Tach '96 F-250 5.8 Brother Les 1987 - 1996 F150 & Larger F-Series Trucks 5 08-28-2014 03:23 PM
78 f150 not firing fordatic 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-23-2014 08:19 AM
94 460 no spark guy9924 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 10-26-2011 09:49 PM
Tags
1987, 460, bad, coil, duralastcontrol, e350, f250, ford, ground, ignition, location, low, module, posts, start, test, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
