Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 07-26-2010, 02:06 PM
mriplaybass mriplaybass is offline
Garage is empty, add now
mriplaybass is starting off with a positive reputation.
Rolls away in park
I have a 2000 Explorer 4x4. Last week, I parked in a friends up hill driveway, and the truck rolled backwards when I took my foot off the brake. As it rolled, I could hear the parking paul clicking, but not engaging. First item on the agenda is to repair the parking brake! Next thing is to repair the parking paul. Any ideas on how to do this? Do I have to remove the transmission, or is it like the A4LD and located in the tail shaft? I have not really crawled under the truck yet to see which transmission is in it. How involved is this going to be?
Thanks!
  #2 (permalink)
Old 07-26-2010, 05:34 PM
ncranchero's Avatar
ncranchero ncranchero is offline
1994 Ford F-150
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
steve.mckellop
First check the bracket under the dash that holds the selector cable in place. They are bad to have the bolts become loose of completely fall out, thus not allowing the selector to completely engage the pawl. Assuming the 2000 Explorer has the 5R55E transmission here are the photos of the pawl/tail housing. Not a bad job at all.
Click the image to open in full size.
Okay, doing a little research I find these are your transmission choices, see your door tag to determine which you have.
Transmission Codes
D — Five-speed automatic overdrive, A5LDE
M — Five-speed manual, Mazda
U — Four-speed automatic overdrive, 4R70W
The A5LDE is as pictured and I believe the 4R70W is like that also.
__________________
Steve,
'94 F150 4x4 4.9L/5-speed/3.55(H9)
'02 Sport Trac 4x4 (lowered 2") FOR SALE
'10 TRANSIT Connect
  #3 (permalink)
Old 07-26-2010, 09:48 PM
Great pictures Steve! Looks very similar to the A4LD. Guess I will have to remove the transfer case and tail shaft to get at the pawl. (yippie!) Maybe it is the under dash bracket as you suggested, and I will get off easy! Thanks
Curt
Tags
1998, 2000, 2004, 5r55, brake, explorer, f150, ford, navigator, park, parking, pawl, roll, rolls, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
