Pinstripe replacement? - Ford Truck Enthusiasts Forums
Old 07-26-2010, 12:41 PM
smashclash smashclash is offline
smashclash is starting off with a positive reputation.
I'm getting ready to paint a new drivers side door of my truck. Problem is my truck is two tone paint (red top and bottom and white in the middle). Anyway, Ford covers the seams of the contrasting paints at the bottom with a plastic trim (which I can remove from the current door and replace with double stick tape). However, the top portion is masked with a 2 stripe pinstripe. Doing a search on this board you have to either buy an entire kit or go to a sign shop. The one currently on the door I'm replacing is fine but is it possible to remove the pinstripe and reuse it on the new door? I'm worried even with a heat gun/hairdryer that when I go to pull on the pinstripe it will either eventually rip as I'm removing it or will stretch out of shape and be unusable.
Any suggestions?
Old 07-26-2010, 01:10 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
No, You will not be able to reuse it ... Sign shop is your best bet. A few bux if that!
-Enjoy
fh : )_~
Old 08-13-2010, 04:54 PM
Colorado Ford Guy Colorado Ford Guy is offline
Colorado Ford Guy is starting off with a positive reputation.
dennis-carpenter.com has the original ford stripe kits.
Vinyl Pin-Striping Removal FORDF100SB 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-01-2015 01:18 AM
Opinions on trim/pinstripes/paint Thunderbird7480 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-07-2011 11:26 PM
Matching Original Pinstripe IzzyR Paint & Bodywork 1 05-05-2008 06:49 PM
Pinstripes Over or Under Clear? Boss50 Paint & Bodywork 7 08-18-2005 08:01 PM
removing pinstripes/vinyl lettering xTREME HAULER Paint & Bodywork 4 04-17-2005 05:38 PM
Tags
1994, 1996, 2003, bronco, davidson, f150, ford, harley, ii, kit, pin, pinstripe, stripe, truckpinstripe, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
