Please Help Decode My VIN
New member here. Just inherited my grandfather's old Ford truck that I would like to restore to as much as original as possible (down to paint color, etc...). Would appreciate if someone here more knowledgeable could help me get information on my truck. Not even really sure what year it is myself (think it's a 62). Here's the information I pulled of the panel on the driver's door.
Warranty #: F10JN340732
W.B.: 114
Color: A
Model: F101
Body: 81A
Trans: A
Axle: 12
Max GVW Lbs: 4000
Cert Net HP: 114
RPM: 3600
DSO: 21
I appreciate any help you can offer. Thanks in advance.
W.B.: 114
Color: A
Model: F101
Body: 81A
Trans: A
Axle: 12
Max GVW Lbs: 4000
Cert Net HP: 114
RPM: 3600
DSO: 21
F10 = F100
J = 223 I6 engine
N = Norfork (built in)
340732 = consecutive unit number, built in October of 62... although it's a 63.
W.B. 114 = short bed
Body 81A = standard cab truck
Color A = Raven Black
Trans A = 3 speed ford standard
Axle 12 = 3.89 rear gears
DSO 21 = Atlanta, Where the truck was orderd from.
Welcome to FTE.
J = 223 I6 engine
Welcome to FTE.
F10 = F100 2WD
J = 223 I6 engine
N = Norfork VA Assembly Plant.
340732 = 1963, assembled October 1962.
W.B. 114 = short bed 114" Wheelbase.
Color A = Raven Black.
F101 = F100 2WD, 4,000 lbs. GVWR
Body 81A = standard cab truck.
Trans A = Ford type 3.03 3 speed Manual all syncromesh transmission.
Axle 12 = Ford 9" Rear Axle / 3.89-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
4,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
DSO 21 = Atlanta, GA Ford District Sales Office, where the original selling dealer ordered the truck from.
J = 223 I6 engine
Since these trucks were also available as a Cab & Chassis, Cowl & Windshield, Chassis and Cowl, or with a Platform (Flat Bed), Platform & Rack (Stake Bed), you cannot assume it's a pickup.
harold4039
04-24-2009 06:46 AM
