Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 07-25-2010, 11:08 PM
mcn420's Avatar
mcn420 mcn420 is offline
Garage is empty, add now
mcn420 is starting off with a positive reputation.
Question 'Blower Flasher Relay Block' location
I'm working on our '00 Expedition's HVAC b/c the front blower will not come on. I found a test procedure to run and there is no power at the EATC blower speed control box, so the next step is to check for voltage b/t at the blower motor relay socket terminal, specifically terminal # 87 which is the black / light green wire, which according to the test procedure is supposed to be located in the center of the vehicle behind the dash. However, I had the main EATC unit, radio, and drivers side of dash off this afternoon and did not see the relay anywhere.
Can anyone tell me where this is located?
__________________
'00 Xpe EB 5.4L, 3.50LS, 150K, going strong
'00 F-250 XLT 4x4, 7.3L, 6-Spd, 145K, 6-pos TS Perf chip, WDsl Gauges~ Pyro&Boost, ColdAir kit, Button Clutch, etc, etc
  #2 (permalink)
Old 07-26-2010, 05:53 AM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Turn the 4-way flashers on and follow the clicking. The flasher relay is in the same box above the driver's right foot.
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #3 (permalink)
Old 07-26-2010, 10:01 AM
mcn420's Avatar
Will do! Thanks projectSHO89!!!
__________________
Tags
1999, 2001, 2003, blower, diesel, expedition, f150, f350, flasher, ford, location, motor, pics, relay, replacement, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
