how does the front end part of the 4WD work? - Ford Truck Enthusiasts Forums
Old 07-25-2010, 09:21 PM
93 mix 'n match's Avatar
93 mix 'n match 93 mix 'n match is offline
93 mix 'n match is gaining momentum as a positive member of FTE.93 mix 'n match is gaining momentum as a positive member of FTE.
what exactly isnt moving while in 2wd? i know the CV shafts are, i know the drive shaft isnt. what part is actually controlled by the vacuum part? is there a schematic or drawing?
thanks in advance.
Old 07-25-2010, 10:39 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
The vacuum motor engages a sleeve internal to the front differencial that locks the two front half shafts togather.
This all happens at the same time the request switch is operated for 4wH or 4wL.
There are electric solenoid vacuum valves on the firewall that do this in response to your selections.
If you do this at idle, you should hear a 'clunk' when the front axle vacuum motor operates.
Otherwise, in 2wd, the front trans drive shaft does not turn because the transmission has not shifted to engage the front drive shaft or the vacuum motors to lock the front half shafts togather.
The combination of electronic control, transmission power flow changes and front axle engagment is what baffles most when they have an issue.
Each part of the operation must be understood to solve an issue unless one is lucky.
Old 07-25-2010, 11:35 PM
so when your driving down the road in 2wd, the actual differential isnt moving?
what im getting at here is im about to change my rear diff fluid. its 260k miles old. 4wd was barely used by the PO, so if the differential dosent move, theres no point in changing the fluid right?
Old 07-26-2010, 02:07 AM
Podaso Podaso is offline
Podaso is starting off with a positive reputation.
I've wondered about that too. I'm interested in any input before I do mine...if I need to. Mine's only got 138,000 miles.
Question before rebuilding Steering Column 66f100project 1961 - 1966 F-100 & Larger F-Series Trucks 9 06-09-2016 07:58 PM
Dash light says 4wd HI but it's not jayhawk714 1999 to 2016 Super Duty 2 01-09-2016 10:48 AM
steering shaft 77highboy400 1973 - 1979 F-100 & Larger F-Series Trucks 14 10-28-2015 06:38 AM
F350 Front Drive Shaft Metallic Squeal grcutter 1999 to 2016 Super Duty 3 05-14-2015 01:58 PM
How many u joints in my drive shaft? 79F250isalive! 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-15-2015 09:24 AM
Tags
2003, 4wd, axle, drawings, drive, end, f150, ford, front, frontend, operated, parts, truck, vaccumm, wheel, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
