How do i put in a new side window
first u remove the door panel
then unbolt the track on the side where the vent window is
then take ur new window and slide down in the door *FROM THE OUTSIDE OF THE DOOR*
after that u will have to play with the regulator until u find a sweet spot for it to slide in the track on the bottom of the glass
after that re bolt the vent window side of the track and roll the window up
dont be afraid to put a little lube on the regulators track
