Painting 88 F-150
Painting 88 F-150
this is my truck and in a couple of months i am going to paint it using dupli colors paint shop lacquer paint that comes pre mixed in the qt cans
and i really dont know how much i need i was figuring about a gallon and a half (6qt) of both the paint and clear and and about 4 cans of filler primer
any ways... what im asking is if id be short on paint or clear?
ill be painting it in a couple months after i purchase a 92-96 front end so im trying to get a estimate on how much cash i need to save
Best advise I can give you is find your local auto paint supply store. You can compare prices, colors and usually get sound advise. Those seem to be metallic colors which are just a little harder to shoot. Single stage with them and you won't be able to sand, where with BC/CC, your clear is where you'll color sand and buff out.
lol im not going to use single stage.... its going to get clear coat...
color sanding and buffing isnt a big deal... i just want a good paint that will last 2 or 3 years and isnt going to cost me an arm and a leg
ill go to a local paint shop and see what colors they got... i dont remember the exact brand of paint they sell but it wasnt bad... painted my dads 86 with a single stage custom yellow it turned out pretty good...
my truck isnt going to be a show truck but it isnt a work truck either...
lol but thanks for the info
how much does ppg cost per gallon?
Take a look here:
TCP Global - Quality & Service Since 1974
Summit racing sell paint as well.
Local auto parts store.. most have PPG and there lower tear paint Omni as well. House of Kolor is good
I would like to try the Summit brand paint as I like the " Black Cherry Pearl " and Im kind of itching to buy some and shoot it just to see how it looks and sprays. LOL
lol i was looking at summit just a few hours ago... their price is actually pretty reasonable so i may go with them... i want to use a gray like is on the truck because it looks good in the jams...
but i may have to go with another color because the candy apple they sell doesnt look like the candy apple from duplicolor sooo idk...
whats ur alls opinions on colors?
should i go with 1 solid or 2 tone it
If you find a PPG dealer local go with Omni MBC basecoat or Shopline JB basecoat, same thing. They run about $100 a gallon and reduce 1:1, so a gal gets you 2 sprayable. You won't be able to get a candy color, but the dupli color isn't a true candy unless it has a basecoat and a tinted midcoat. You can do the same thing with Omni, but the expense goes up along with the difficulty. You'd be better off finding a pearl red that is close to what you want instead. As far as going 2 tone or single, I always thought those 2 tones on the 80's fords looked good. It will add an extra expense though, as red is the most expensive color. If you did your second color a different non-red shade color it would most likely be the same cost as if you did it all one color. Plus, painting a 2 tone is easy with base clear.
thinking about the Wimbledon white for the center section, or all one color, I'm not sure either.
