TCM Issues? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
TCM Issues?
Old 07-25-2010, 03:07 PM
embry1123's Avatar
embry1123 embry1123 is offline
embry1123 is starting off with a positive reputation.
TCM Issues?
Well after checking into the no start issue, I believe that I am experiencing an issue with the TCM. Also found out that my keep alive memory is showing a fault, 0 volts. The truck will not start unless persuaded to do so by jumping the starter wire and then it won't move in a forward direction except in 3rd gear only. Reverse works, but no reverse lights, and the parking sensors are also not functioning. Does this lead anyone else to believe that the TCM has died, or could it have something to do with the power supply to the TCM? I cannot find where power is supplied from for this unit.
Thanks-
Old 07-25-2010, 03:10 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
PCM may be affecting the TCM not allowing the xmsn to shift properly...Wait a second...is this the same truck you're talking about with the power draw?
Old 07-25-2010, 03:16 PM
embry1123's Avatar
ok... what is the xmsn? Truck runs fine, driveability along with not starting with the key seems to be the issue, but the autoenginuity scanner is showing a communication failure with the TCM. When I try to log directly into the TCM the scanner states that it cannot be found
Old 07-25-2010, 03:18 PM
embry1123's Avatar
Quote:
power draw? no
Old 07-25-2010, 03:19 PM
xmsn = transmission....sorry...military jargon
Old 08-26-2010, 08:07 PM
justinmix justinmix is offline
justinmix is starting off with a positive reputation.
I was curious if you ever figured out what your problem was. I have the exact same thing. Customer replaced the batteries and now has a no crank condition. Starter relay chatters and starter halfway tries to engage. I can jump the starter relay and get it to crank and start up fine. Relay pins have good key on voltage, and good 12 volt signal when moving key to start position. It seems to be a problem with the ground side of ther starter relay, which I'm assuming is controlled by the TCM. Can communicate with the PCM ok and no codes logged, but when I try and receive TCM codes it says no communication. Overdrive light is not working and tranny is stuck in 3rd gear. Have checked all fuses and relays, main hots and grounds and can't find anything. Is the TCM/PCM built into one box on these things? Any help would be appreciated. Thanks!
Old 08-26-2010, 09:04 PM
embry1123's Avatar
I did get mine fixed and I apologize for having not listed what I found. Thought I had done that. Anyway, I ended up pulling the fuse block and simply removing and re-installing ALL of the plugs on the back side. After I did that I immediately began getting communication with the TCM again. Problem was a bad connection and the TCM had no power/ground. Hope this helps and that your problem is as easily solved.
Old 08-30-2010, 06:21 AM
Thanks for responding. This post was the only thing I could find anywhere that sounded like the same problem I was having.
So I tried the same thing, pulled the fuse block out and checked all the connections. No signs of corrosion or anything strange. Cleaned up all the connectors with contact cleaner and reinstalled fuse block. Sure enough truck started fine and tranny is shifting normal again. Very strange and I guess just a weird coincidence that it happened after the batteries were replaced. Thanks again for the help!
Old 04-29-2015, 09:20 PM
BGotti's Avatar
BGotti BGotti is offline
BGotti is starting off with a positive reputation.
PCM/TCM
I having transmission issue , tow haul flashing , only 3 gear , no back up lights , no start after it warn , idles up after its started , I replaced the TRSensor in the transmission , checked the plugs behind fuse panel I was told it's the tcm / pcm , if I turn key on after it hit and start it manually it starts right up , now mine is a title 2004/ build date is 9/03 which I told only 03 pcm will work, so I have a 03 f250 6.0 automatic aswell , can I put that PCM in the f450 to see if it's the issue , or is there a way to test my PCM thx Ben Gotti
PCM/TCM or Cable? chewedtoothpick 6.0L Power Stroke Diesel 14 06-15-2014 10:11 AM
03 no crank no communication with tcm bigfordandjeep 6.0L Power Stroke Diesel 10 10-06-2012 08:50 PM
A quick cautionary comment re: "Wow what a difference in shifting!" rdenis 6.7L Power Stroke Diesel 42 05-12-2011 08:29 PM
trans problem? embry1123 1999 to 2016 Super Duty 9 07-27-2010 10:12 PM
TCM (transmission control module) m350 6.0L Power Stroke Diesel 2 02-16-2007 09:50 AM
Tags
07, 08, 2008, 250, 73, 97, duty, f250, ford, issues, located, location, super, superduty, tcm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
