replacing Exhaust manifold - Ford Truck Enthusiasts Forums
Old 07-25-2010, 02:04 PM
JP_McCann JP_McCann is offline
JP_McCann is starting off with a positive reputation.
1997 F150 4.6. How hard is it to remove and replace the manifolds. i get a clicking sound from them. I searched and saw a lot of threads talking about replacing the manifolds. what is the best way to remove the olf manifolds? i know the machanic that I use just cuts the nuts off and goes from there. Could I get an impact on them and try that way or are they likely to break off doing that? anyone have suggestions on headers vs manilfolds or what headers to get. All help is great.
Old 07-25-2010, 02:38 PM
cogden's Avatar
cogden cogden is offline
cogden is starting off with a positive reputation.
The best way to remove exhaust manifolds on these trucks is very carefully with lots of PB Blaster or some other penetrating oil. Soak the studs with penetrating oil hours before you plan to remove the manifolds and then turn the nuts very slowly and methodically. The exhaust manifold studs often stick and it is very easy to break one off in the head. For that reason, you should avoid using an impact wrench. Also, it is easier to reach the manifolds on your truck if you remove the front wheels and the front plastic wheelwells.
Old 07-26-2010, 07:08 AM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
cogden is right, soak them good. i broke one off in the block and it was a pain. i had to remove starter, plastic inner finder and jack the motor up to get that bolt out. as for the header vs manifold question, its up to you. shorty headers will give you better power in the higher RPM's and long tube headers will give you lower RPM power. i have pacsetter shorty headers and they do make the truck sound much better and help out with passing gear at 70mph.
Old 07-26-2010, 11:38 PM
1975IH200's Avatar
1975IH200 1975IH200 is offline
1975IH200 is starting off with a positive reputation.
Quote:
Did you READ the threads??? There is lots of good info in those threads and all your questions are answered there already, IMHO.
I have added my experience in two or three of the exhaust manifold threads.
headers / manifolds advice WhiteTiger 1987 - 1996 F150 & Larger F-Series Trucks 2 09-09-2013 10:00 AM
manifold gasket octaneforce Ford Inline Six, 200, 250, 4.9L / 300 7 11-09-2010 11:34 AM
exhaust manifold gasket Old Brown Truck 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 05-08-2010 12:05 AM
1990 302 exhaust manifold/headers?? 00bucker 1987 - 1996 F150 & Larger F-Series Trucks 2 02-20-2007 09:40 PM
headers vs manifolds lsrjf 1967 - 1972 F-100 & Larger F-Series Trucks 24 11-27-2001 12:18 AM
Tags
2003, 2005, 46, exaust, exhaust, f150, f250, f350, ford, manifold, manifolds, maniforld, replace, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
