power rack for MII, bolt hole location from the frame rail?
I installed a power rack in my truck that has a MII ifs. The problem is i have more turning radius on the pass side than the drivers side. I have adjusted the tie rod ends in and out but still cant get it. Im left to think that the tabs for the mounts are in the wrong location. I just would like to see what others have theres before i go cutting it up and move it over. When i bought the rack they where to install the rack extensions on. I have not called the supplier i bought this from yet. Thanks for your help!!!
You simply count the number of turns on the steering wheel from lock to lock (full left to full right), then split the difference for center. So if you have, say, 3 1/2 turns lock to lock, come back 1 3/4 and you're good to go.
Mine measure drivers side 6.5" from boxed frame rail to center of bolt and passenger side is 8.25" from boxed frame rail to center of bolt. All measurements between bolts should be the same. My 2 cents!
is that inside of the chassis? mine was to the outside edge
