1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Help! rear bottom leaf springs keep turning
Old 07-25-2010, 05:33 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
first why wouldnt it work? both EX and SD use the same axles springs and clamps so if SD are that way and they both have 3 inch springs why would turning them the right way not work? are the holes not wide enough or what
Old 07-25-2010, 05:38 PM
Rongold's Avatar
Rongold
Rongold is offline
SPRING TWISTING
Scaler is right. I just went out to my truck again, and my upper plate is on 90 degrees to yours, with the raised edges facing forward and backward. I looked in a couple of shop manuals, and they all show the F series and Excursion that way. I measured the 4 holes in the plate, and if you can twist those plates, your U-bolts will be about 1/2" closer together like they should be. Those U-bolts should be hugging the pedestal that the spring sits on. It's possible that you have the wrong U-bolts, as Ford had two different axle tube sizes, and the difference was about 12MM or a 1/2 inch. You may have to get U-bolts for the smaller diameter axle tubes.
RON
Old 07-25-2010, 05:53 PM
amsk8er1983's Avatar
amsk8er1983
amsk8er1983 is offline
Ok thanks for doing those measurements maybe you guys are right I'm just positive I did that. But it make sense if it move the u-bolts closer in preventing the leafs from turning. I will give that a shot. I didn't really like the u-bolts the sent me anyway they were way to long to where I couln't even get my torque wrench on so I had to shave them down. You guys think I should get new u-bolts? I will just go with a cheaper brand bolt because icon wants $80 for 2 new pairs.
Old 07-25-2010, 06:04 PM
Rongold's Avatar
Rongold
Rongold is offline
U-BOLTS
Wherever you get them from, make sure they are for the 108 mm diameter axle tubes. Ford has U-bolts listed for the Ford axle as 108 mm diameter tubes and for the Dana axle as 118 mm diameter tubes. You probably have the U-bolts for the larger diameter tubes. You can probably straighten out the plates with a BFH, or hopefully they will spring back into shape after you loosen the nuts. Just make sure that whatever U-bolts you get, they should hug the axle tube fairly tight--you may even have to hammer them up onto the tube. If you live or work near a fairly large city, hopefully there should be a spring shop there. You should be able to pick up a set of 4 for under $50.
RON
Old 07-25-2010, 07:15 PM
tawells01's Avatar
tawells01
tawells01 is offline
I see you are in Colorado. If you are near Denver, go to Denver Spring they can make them to what ever specs you want. I had them make mine.
Old 07-25-2010, 08:55 PM
amsk8er1983
Ok thanks guys that's why I love this website.
Old 07-25-2010, 10:07 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
never reuse U-bolts..
they are torque to yield bolts..
only good for one tension, then replace.
bkgeig
08-11-2019 11:36 AM
JonathanN
150
09-07-2016 02:34 PM
javieljb
2004 - 2008 F150
22
03-30-2011 04:05 PM
amsk8er1983
07-27-2010 11:37 PM
BigF350
20
03-17-2010 10:52 AM
Quick Reply: Help! rear bottom leaf springs keep turning
