volare issues
volare issues
so, the new 56 I picked also has a volare.. but whoever installed it didn't seat it up into the frame.. the frame sits on top of the volare cross member..
and I have some weird steering behaviour.. VERY light straight ahead..
and poor turning,,, then ALL OF A SUDDEN, like major steering change.. yank the wheel out of your hand type change..
I haven't taken it to an alignment shop yet.. just 15 mile drive to get it inspected and back.. and that was white knuckle the whole way there and back..
the upper arms are canted WAY back(mega + caster), as compared to the volare setup in the green truck.. (the green truck exhibits a little of this same behavior)..
open to ideas..
Sam
open to ideas..
Sam
yes, anti-dive is wrong. but I don't see any issues in that case.. and I have seen cases where this was done, maybe not for the right reasons..
I didn't buy the truck for the chassis, but it would be nice to drive it some.
the green one came as a pile of worn out parts..
I already know that lack of heat insulation on the firewall and no vent or vent windows for air circulation makes for a hot cab..
Sam
Sam
Sam,
I have seen some effies from around Bham that have had that same volare (directly sitting under the frame) and the owners are not very happy with it. They drive like crap but the guy that is doing all these is a hell of a salesman on these budget IFS and people are still getting them. I am not much on the looks of my volare setup installed notched in the frame but the drive has been enjoyable after I reduced the pressure on the mopar steering box. I would just cut that out and renotch it and put it in there correctly
got to go measure the lower arm pivot relative to the ground.. front to back
that might be the key..
| on the green truck, the lower arm is tilted down towards the front, at 5.3 degrees both sides.
| on the red truck, the lower arm is tilted down towards the back, at 1 degree, both sides.
| so, a 6.3 degree tilt back difference..
| I can't wait to get it to an alignment shop..
| caster must be close to 15 degrees the way its set now..
sam
sam
so, caster is negative when it leans forward and positive when it leans back.
so, by having the front of the volare subframe LOWER on the chassis, everything tilts forward..
this isn't what I am measuring however.. green 5.3 lean to the front, red 1 degree lean to the rear.
| I'm gonna have to remeasure
here is the cut I made on the left chassis rail for the green truck,
from the templates.
and I don't doubt that I will have to cut it out.. plasma cutter to the rescue!!..
can't tell yet, but one torsion bar may be bent as well..
Sam
from the templates.
Sam
It's real difficult to diagnose problems with front end geometry from pictures and descriptions, but I would try to find a stock volare (the whole car) to measure if at all possible. Measure A arm pivot angles relative to the ground and the lower pivot height.
Then do what it takes to duplicate those measurements on your frame.
The steering behavior is symptomatic and likely due to way too much caster. When you turn the wheel from lock to lock does the chassis rise and fall noticably and the inside tire lies strongly back at the ends of the steering? I doubt that any realignment short of reinstalling it will help much.
I definitely would not even attempt to drive it in this condition it's an accident going to happen should you need to make an emergency maneuver.
I've never seen a bent Mopar torsion bar, just broken ones.
CharlieLed
11-04-2013 09:23 AM
fatfenders
86
02-26-2013 07:48 PM
sdetweil
141
01-01-2012 05:15 PM
KustomKidd
05-10-2010 09:37 AM
sdetweil
01-20-2006 06:31 PM
66, adjustment, caster, castor, f1, f100, fitting, ford, frame, independent, issues, suspension, volare
