96 ranger......fuel gauge doesn't work....where to start? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-24-2010, 05:46 PM
waynaferd's Avatar
waynaferd waynaferd is offline
waynaferd is starting off with a positive reputation.
Before I drop the tank I was wondering if there's a more common electrical problem in the gauge or wiring to check first. Right now I go 300 miles then fill up, but would like to get the gauge working.
Thanks!!
Old 07-24-2010, 10:21 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
It is probably the sender unit in the tank. If you can disconnect the connector on top of the tank you can test both the gauge on the dash and the sender in the tank. The yellow with white stripe wire is the feed from the sender black with yellow strip is the ground connection. Use an ohm meter and connect between the b/y y/w pins on the sender you should have a reading of between 22 ohms and 145 ohms depending on fuel level. 145 ohms is full. It will probably read way out of that range. Either zero of infinity. If this is case you will have to replace the sender If the values are right then you need to test the gauge a 60- 70 ohm resistor between the y/w and b/y wire should have the gauge reading half scale If it doesn't do anything then you have to start looking for problems backup the line towards the gauge itself. It is fed from fuse 11 from the cab fuse box but so are the other gauges and I assume they are working. Good luck
Old 07-25-2010, 02:48 PM
waynaferd's Avatar
oh, nice!! Thanks!!
Old 07-25-2010, 07:46 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by waynaferd View Post
oh, nice!! Thanks!!
if your truck has been in maine it whole life i can just about gurantee you need new hangers and shackles on your rear leaf spings.........it might be easier to removee the bed to get the fuel tank and then change the shckles while it is off
Old 07-26-2010, 06:40 AM
waynaferd's Avatar
I can just about guarantee your right and it needs about 6" of frame rail on the drivers side so I can bolt on a new hanger!! The spring eyelet is resting up against a 2x4 so it doesn't wear thru the bed floor and I gotta ratchet strap holding up the bumper, LOL.
Right now I wanna get any possible electrical, gauge, dummy light, and ABS issue squared away, as I'm slowly collecting goodies to drop a 5.0 in, and once the front end "drop" or sag is established, I'm dropping the rear with a flip and DJM shackles, and new OE hangers.
I'm using a complete 95 f-150 MAF 5.0 with E4OD(?) and although the wiring looks fairly easy, I wanna be sure!!
HELP: Dashboard Gauges Not Working mpope 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-06-2017 04:08 PM
1965 F-100 speedometer gauges and lights Fords & Whalers WTB - Parts & other 2 08-29-2016 10:56 PM
Gauges not working badaz4570 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-31-2016 03:46 PM
All gauges dont work Michaelkrieger 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-25-2016 08:39 AM
69 f100 gas gauge and oil temp gauge not working gabestalker 1967 - 1972 F-100 & Larger F-Series Trucks 6 05-27-2014 02:46 AM
Tags
1996, 400, 60s, 96, 97, doesnt, engine, expedition, ford, fuel, fuse, gage, gas, gauge, guages, ranger, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
