BYE BYE DIESEL, HELLO V-10!
Old 07-24-2010, 01:14 PM
scottman70's Avatar
scottman70
scottman70 is offline
4 trips in my 6.0 and 4 breakdowns! I'm done! Selling my EB 6.0 and buying an 05 V-10 today guys! I have just had it with this last EGR Cooler/oil cooler repair! 80K miles and I have done maintenance galore on all items for my 6.0 religiously?? V-10ers I have actually been swayed and am going to look at an 05 4x4 with 60K miles on it today! Anyone interested in an 04 EB with a new EGR cooler and oil cooler that is all stock PM me, I'm in AZ!
Old 07-24-2010, 01:45 PM
jh818's Avatar
jh818
jh818 is offline
Funny thing is once you sell the diesel, you could buy the V10 outright with some cash to spare.
Old 07-24-2010, 01:55 PM
scottman70's Avatar
scottman70
True true! I have just lost confidence in my Diesel Ex. I have to be able to go on 1 trip towing my trailer without something breaking and ending my trips early.
Old 07-24-2010, 02:22 PM
cbradford's Avatar
cbradford
cbradford is offline
I have an 05 V10 with 4:30's and it tows my TT great as long as I keep feeding it!!!
Old 07-24-2010, 02:44 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
If you notice on V-10's the only problems are:
Ocassionaly COP's which is usually a boot instead of the COP.
Exhaust studs.
Once in a blue moon a fuel pump.
Alt. goes bad at about 80,000 same as a diesel.
Plug threads on up to 2002 models very uncommon on later models.
Oil change 6 quarts and 1 filter.
Fuel mileage 10.9 to 12.3 City and 13.7 to maybe 15 Highway.
I have a V-10 and am happy. 400 mile trip 44 gallons of gas or 1 tank.
Now as a diesel owner "you know the rest of the story".
Old 07-24-2010, 02:51 PM
scottman70's Avatar
scottman70
Exhaust studs.
Well if the HG's go out on my 6.0 that's another $3K, HPOP, injectors, turbo and on and on! This thing is going to be a money pit in which I don't have the funds to throw at it!
Old 07-24-2010, 02:58 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
As I have always said:
Its miles per-dollar not miles per-gallon on any car or truck you own. The over all expense is the bottom line.
Old 07-24-2010, 03:13 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Guess I''ve been lucky with my 7.3...
Old 07-24-2010, 03:23 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
well goodluck! i loved my V10 and i think i'll be going with another. but i am looking at a 7.3
post pics of the new one when you get it!
Old 07-24-2010, 03:29 PM
tonyurban's Avatar
tonyurban
tonyurban is offline
Exhaust studs.
I'm new to the Ex/V10. Could you elaborate on these a bit?
Thanks,
Tony
Old 07-24-2010, 04:10 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
Not to hijack the thread but:
A miss fire is usually contributed to a bad COP Coil on Plug. The coil has a boot on the bottom of it that goes on the spark plug. If the boot gets dried out cracks or whatever the spark can go through the boot and ground out against the cylinder head. This will caise a mis-fire on that cylinder. The standard repair is replace the COP when all it needs is a boot, about 4.50.
One way to check the boot is look for a grey or brown streak on it.
Squeeze it together and look for cracks in the rubber. If either exists then replace the boot.
Welcome aboard Tony!
You will love this site.
Urbanxx
2003 Excursion Limited
Black V-10 4x4
Old 07-24-2010, 04:16 PM
tdappleman's Avatar
tdappleman
tdappleman is offline
Welcome to the gasser side. I originally was looking for a diesel Ex and ended up buying the V10. It tows my Sea Ray 270 quite well (~10000 lbs + 1600 lb trailer) - no problems on ramps, getting up to speed or holding speed on the highway. Mileage does suck - but just using MPG as the criteria would have taken me about 6 years to break even since the diesels were 4-5k more in my area than the V10s. I'm getting about 11-11.5 around town and 14-14.5 on the highway - I'm not easy on it at all. It's quite, no smells, no EGR problems, no 15 quart oil changes, no 15k fuel filter changes, etc.... You'll get plenty of other opinions but welcome to the V10 'dark side' :-) It's a great engine and you still have a great truck around it! After all it's still a Ford!
Old 07-24-2010, 05:35 PM
Shepherd2's Avatar
Shepherd2
Shepherd2 is offline
Well put. Never could understand the fascination with diesels. Must be a testosterone thing cause it certainly isn't cheaper to operate.
Old 07-24-2010, 07:46 PM
bigdaddymedic2000's Avatar
bigdaddymedic2000
bigdaddymedic2000 is offline
i've not had the plug problem....mine had the original ones at 163,000 miles... engine has been fine....other stuff has been replaced...
Old 07-24-2010, 07:55 PM
cbradford's Avatar
cbradford
Scott, I don't think the 05's had much of a plug spitting problem.
Quick Reply: BYE BYE DIESEL, HELLO V-10!
