Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- How to Replace Serpentine Belt
Step by step instructions for do-it-yourself repairs
Serpentine Belt Diagram
Does anyone have a picture or diagram of the drive belt system, number of idle pulley/belt tensioner. I have only one alternator, the issue I'm dealing with is a sqweelling noise coming from the front of the motor, and I would like to get some insight as what I might have to replace.
Thanx Halfbolt
Thanx Halfbolt
Is the compressor still in place?
If yes you may find it less work to just remove the nut in the center of
the clutch and that will let the pulley just spin. If the pulley locked up
then your going to have more fun. The clutch is lower left of the top
image. You just remove that nut in the center. The pulley rides on a bearing
that sits on the compressor nose. It's held in place with a snap-ring and
an interference fit.
Merry Christmas
Sean
6.0L Tech Folder
Cookiehead29 Welcome to FTE
Marry Christmas
Sean
6.0L Tech Folder
Marry Christmas
Sean
6.0L Tech Folder
Once that bolt is out you can drive it all you want. What it does is remove the
compressor from the system by not letting the clutch plate close down onto the
pulley. When you remove it look for the small washers on the shaft and also remove
them and save in a safe place with the clutch and bolt.
Merry Christmas
Sean
6.0L Tech Folder
Merry Christmas
Sean
6.0L Tech Folder
HH65cpilot
1999 to 2016 Super Duty
07-30-2022 06:01 PM
TobiasScott
09-02-2021 04:58 PM
norvillebob
64
02-07-2016 11:45 AM
