Serpentine Belt Diagram - Ford Truck Enthusiasts Forums
Old 11-12-2014, 01:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Old 07-24-2010, 12:07 PM
halfbolt's Avatar
halfbolt halfbolt is offline
halfbolt is starting off with a positive reputation.
Does anyone have a picture or diagram of the drive belt system, number of idle pulley/belt tensioner. I have only one alternator, the issue I'm dealing with is a sqweelling noise coming from the front of the motor, and I would like to get some insight as what I might have to replace.
Thanx Halfbolt
Old 07-24-2010, 12:38 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
Maybe this will help,,,
Name:  Serpentine Belt Route Picture.jpg
Name:  Belt Tensioner 02.jpg
Old 12-09-2011, 04:38 PM
F250MAMOU F250MAMOU is offline
F250MAMOU is starting off with a positive reputation.
Awesome picture! Thanks for posting!
I'm trying to change out my alternator on my 2007 F250 diesel and couldn't find the tensioner. I'm going find it now...thanks for the pic.
Old 12-08-2015, 10:53 PM
Cookiehead29 Cookiehead29 is offline
Cookiehead29 is starting off with a positive reputation.
Need to no what size to use to bypass ac/ compressor
Hello everyone. I have a 2003 Ford 350 power stroke and the / compressor went out. I'm trying to bypass it and put a shorter belt on it but do not know the size. Does anyone know what size belt I need. Thanks if anyone can help
Old 12-09-2015, 12:40 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Quote:
Cookiehead29 Welcome to FTE
Is the compressor still in place?
If yes you may find it less work to just remove the nut in the center of
the clutch and that will let the pulley just spin. If the pulley locked up
then your going to have more fun. The clutch is lower left of the top
image. You just remove that nut in the center. The pulley rides on a bearing
that sits on the compressor nose. It's held in place with a snap-ring and
an interference fit.
Merry Christmas
Sean
6.0L Tech Folder
Old 12-09-2015, 05:56 AM
Marry Christmas
Sean
6.0L Tech Folder
Yes the compressor is still in place. And if I do remove the bolt and it do crank. Can I drive the truck like that. Is so for how long. I put a new fuse in it and it keep blowing. The fuse for the ac clutch I mean. Thanks. I'm going to try it and let you no.
Old 12-09-2015, 05:22 PM
Yahiko's Avatar
Once that bolt is out you can drive it all you want. What it does is remove the
compressor from the system by not letting the clutch plate close down onto the
pulley. When you remove it look for the small washers on the shaft and also remove
them and save in a safe place with the clutch and bolt.
Merry Christmas
Sean
6.0L Tech Folder
belt diagram Fitzgerald_welding 1987 - 1996 F150 & Larger F-Series Trucks 11 03-15-2016 05:19 PM
Exhaust Leak/Smell in cab halfbolt 6.7L Power Stroke Diesel 3 11-02-2015 08:03 PM
belt diagram zp2141 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-21-2015 01:09 PM
Front end Shimmy halfbolt 6.7L Power Stroke Diesel 1 05-03-2014 08:39 PM
alternator belt diagram tomn 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-15-2001 07:27 AM
Tags
2000, 2005, 54l, 60, belt, diagram, diesel, diy, excursion, f150, f350, ford, powerstroke, schematic, serpentine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
