how much does a superduty weight? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-24-2010, 10:07 AM
97puller's Avatar
97puller 97puller is offline
97puller is starting off with a positive reputation.
Does any one know how much a regular cab four wheel drive super duty weighs?
Old 07-24-2010, 11:18 AM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
What year? They get heavier after certain years.
Old 07-24-2010, 11:21 AM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
Dually or single, which SD, automatic, engine?
Old 07-24-2010, 11:29 AM
97puller's Avatar
2000, single wheel, manual trans, 5.4v8
Old 07-24-2010, 12:36 PM
Grumpy Moose Grumpy Moose is offline
Grumpy Moose is starting off with a positive reputation.
My guess would be somewhere around 6000 lbs.
Old 07-24-2010, 01:08 PM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
6000 and up or so. Some are really heavy!
Old 07-24-2010, 03:29 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
A 2000 Reg Cab, 4x4, Stick, with a 5.4L should weigh around 6,000#
A 2008 Reg Cab, 4x2, 6-spd, 5.4L weighs in just under 5,900#
Old 07-24-2010, 04:54 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
8800 pounds GVWR
-3195 Max Payload
= 5,605 pounds empty
That's the best I can figure using this.
Old 07-24-2010, 05:59 PM
Quote:
Yea, I'm just taking a SWAG.
I recently took my signature truck to the scales and got 6900 lbs empty. I figure my service body weighs 2 to 3 hundred lbs more than a standard truck bed. Figure another 100 lbs for the automatic transmission, and another 3-4 hundred for the longer wheelbase. That should put the OP's truck at right around 6000 to 6200 lbs.
Old 07-24-2010, 09:38 PM
Mud-and-Guts's Avatar
Mud-and-Guts Mud-and-Guts is offline
Mud-and-Guts is starting off with a positive reputation.
I pulled my 99 f250 super duty V10 automatic 4x4 short bed super cab truck across the scales to find 6500lbs with no tool box and empty bed...
Old 07-24-2010, 11:33 PM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
My 4x4, crew cab, short bed V10 Lariat with a bed cap wieghs in at 7,000 even.
Old 07-25-2010, 06:49 AM
MC9 MC9 is offline
MC9 is starting off with a positive reputation.
My 08 V-10 SC LB weighed 6940 at the cat scales.
Old 07-25-2010, 10:19 AM
msalyer msalyer is offline
msalyer is gaining momentum as a positive member of FTE.msalyer is gaining momentum as a positive member of FTE.
my '01 supercab 4x4 shortbox automatic weighs 6450 with a full tank of gas and no driver.
Old 07-25-2010, 11:44 AM
VintageSCUBA's Avatar
VintageSCUBA VintageSCUBA is offline
VintageSCUBA is starting off with a positive reputation.
My 2011 F-250 6.2 Lariat SC, FX4 with 8' bed has a curb wt. of 6,700
Old 07-25-2010, 07:25 PM
FORDTUF1's Avatar
FORDTUF1 FORDTUF1 is offline
FORDTUF1 is gaining momentum as a positive member of FTE.
Well I had my 99 and my 02 (250 4x4 V10 Super Cab Auto) weighed in at 6450 also with full tank of gas. That makes three of us that are right on the same mark practically. So to the OP, unless you weigh it you are probably within + or - 100 pounds of 6000.
How much does it cost... Jim83 6.0L Power Stroke Diesel 4 11-17-2011 05:43 PM
How much does it weigh? OrangeJuice FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 03-17-2011 07:29 AM
How much methanol does it take rrrrick Alternative Fuels, Hybrids & Mileage 2 03-02-2008 11:06 AM
1978 f250. How much does it weigh? scotts66charger 1999 to 2016 Super Duty 0 08-21-2006 07:54 PM
How much does a 300 six weigh? ttnjr Ford Inline Six, 200, 250, 4.9L / 300 6 01-31-2005 10:19 PM
Tags
03, 2000, 2002, cab, diesel, dose, duty, extended, f250, f550, ford, super, v10, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
