gas tank problem...HLEP!!!!!!!!!!!!!!
on
ever since i`ve had my truck, i`ve had this problem. when i go to fill up at the pump, i put the gas hose in and clicks at around 50 cents and thats how a have to fill my truck up.....50 cents at a time. i`ve resorted to filling up 5 gallon gas cans and parking my truck on a hill with the driver side being the highest point and it seems to fill just fine and doesnt overflow and seems to go in fine. i`ve put a new gas fill hose on it but the problem is the same and no better. someone please help me, i feel like am putting together a white puzzle while bangin my head against a wall tryin to figure this out
How does a gas pump know to shut itself off?
May 29, 1981
Dear Cecil:
Cecil, old buddy, even though I am receiving a doctorate this spring, the old adage that the more you learn the less you know still holds true. So tell me this: how does a gas station pump know when to turn off before spilling gallons of gas onto the pavement?
— Ethel Pumper, Dallas
Cecil replies:
Pal, you're going to need a doctorate to understand the following, so cleanse your mind of distracting thoughts. In a gas pump handle you have two valves: the main valve, which is actuated by the oversize trigger you squeeze to make the gas flow, and the check valve, which lets gas flow out but won't let anything back in again, thus reducing fire hazard. In the seat of the check valve you have a little hole. To the backside of this hole is connected a Y-shaped tube. One branch of this tube runs down the nozzle and exits at the tip while the other runs back to a diaphragm connected to a release mechanism on the main valve. When you squeeze the gas pump trigger, gas running past the hole in the check valve sucks air out of the Y-shaped tube. (This is because of the Bernoulli principle: a moving stream of fluid tends to pull things in from the sides. Take my word for it.) As long the end of the Y-shaped tube exiting at the spout is unobstructed, air is simply pulled into the tube and nothing much else happens. However, as soon as the gas in your car's fill-up pipe gets high enough to cover the end of the tube, a partial vacuum is created therein, which yanks on the diaphragm, releases the main valve, and shuts off the gas. If the gas happens to be especially foamy one day, it may actuate the release mechanism prematurely, with the result that you end up with less than a full tank of gas. Simple, huh? Sure, just like nuclear fission. Stick with English lit.
— Cecil Adams
May 29, 1981
Dear Cecil:
Cecil replies:
— Cecil Adams
on
there is a smaller tube inside of the filler hose, about as big around as a nickel. that tube is supposed to be inserted into the top of the filler hole in the tank and the top of the filler neck. if the tanks have ever been pulled out then it is no longer in the proper place in the filler hole in the tank. that is the vent which lets the air out while your filling. i just dropped both of my tanks and the only way i can see to reinstall it correctly is to pull the bed off so you can access the tank from the top once it is strapped in. inside the filler hole in the tank there is some sheet metal tabs that you have to slide the smaller tube into and that is what holds it up out of the flow of fuel so the air can escape. when the were installed at the factory im sure they put the tanks in the frame first for ease and speed of installation.
mjmck
1999 to 2016 Super Duty
59
08-26-2017 04:23 PM
mrollings53
08-02-2016 12:47 AM
73ragnar
06-12-2011 07:56 PM
