Navi shock/strut
Here's the info from my service manual, the pix don't come through , but this should help. You should really replace both shocks at the same time
<TABLE width="95%"><TBODY><TR><TD>SECTION 204-05B: Vehicle Dynamic Suspension — 4-Wheel
</TD><TD align=right>2002 Expedition/Navigator Workshop Manual
</TD></TR></TBODY></TABLE>
REMOVAL AND INSTALLATION
<HR>Air Shock Absorber
****** name=tps_proctitle content="Air Shock Absorber">Removal and Installation
NOTE: The vehicle must be positioned on a suitable lifting device prior to deflating the air suspension switch.
- Deflate the air suspension system. For additional information, refer to Ride Height Adjustments in this section.
- Raise and support the vehicle. For additional information, refer to Section 100-02 .
- On LH air shock removal only, disconnect the top of the front height sensor from the upper frame bracket.
- Remove the air shock lower nut and bolt.
- Disconnect the air spring solenoid air line.
- Compress the quick connect locking ring and pull out the air line.
- Remove the air shock upper nut, grommet and the air shock.
- NOTE: After installing the air shock, it is necessary to inflate the air suspension system. For additional information, refer to Ride Height Adjustments in this section.
NOTE: When installing the air lines, make sure the white air line is fully inserted into the fitting for correct installation.
To install, reverse the removal procedure.
Nice...thanks a lot for the fast reply...too bad the pics don't show...if possible could u email me ( info@amvauto.com ) the pics? or maybe send it in a word doc? If not thats cool...but thanks either way for this.
have a good weekend !
