2011 Excursion ( Custom Autos By Tim) PICS
Since it lloks like the second row doors are from an Excursion, I wonder where he got the interior door panels from? The Excursion doors are a little bigger than a Super Duty crew cab.
As far as the fender flares, maybe they should look at fender cladding that overlaps the front fender lip and make a matching set for the rear.
They're the SD 2011's doors, they chop the front end off of the truck, extend the frame (if needed), and drop the rear end of an excursion on it, weld it up, and add matching trim.
no, those are excursion rear doors. they are longer and have a sloped window insted of the square window in the rear of the crew cab super dutys.
my guess and would also be the easy way of doing this swap is they cut at the a-piller/windsheild and add a excursion body, in this case.
the 6 doors are differant as you can see the use of the crew cab doors in the middle.
Check out the 2011 Excursion By Custom Autos By Tim
http://www.****************.com/2011FordExcursion.html
pdombrowicki
09-14-2012 07:54 AM
pdombrowicki
04-01-2011 10:40 AM
pdombrowicki
09-22-2009 12:34 AM
